Sounds like stones in the hubcap?
Old 12-14-2013, 03:21 PM
djousma's Avatar
djousma
djousma is offline
Oddest thing. No complaints about the driveability of the truck, runs great, drives/stops straight, etc.
However, when driving really slow (<3 mph), and I put the window down it sounds like I can hear what sounds like stones in a hubcap. Sound seems like its coming from wheel area, not sure where. Not very loud, have to turn radio off, put window down to hear it.
Anyone heard of this? Just had tires rotated about 1000mi ago at the dealership, they checked brake pad thickness(about 50% left).
Dave
Old 12-14-2013, 03:33 PM
marchare011's Avatar
marchare011
marchare011 is offline
I had that same thing happen this spring after driving thru a water hole while four-wheelin. I assumed it was a small rock or the like in the front caliper area. Same scenario to hear it. I chased that ghost for a month or better. There were times when the noise seemed to come from the transfer case area more than the front brakes. Wife could hear it too. I would drive down a forest service road at 2 mph with the door open and hanging out trying to isolate the noise. Never did find it, no issues yet. Radio is back up to proper listening level and I've moved on. I still think I had a rock where it didn't belong.
Old 12-14-2013, 04:01 PM
djousma's Avatar
djousma
djousma is offline
thanks for the response. Don't think its the transfer case, didn't have it in 4x4 Could be something between brake rotor and the inner dust shield I suppose.
Old 12-14-2013, 04:58 PM
madsonp's Avatar
madsonp
madsonp is offline
Crawl underneath and check for rocks along the drive shafts, I've had this happen a few times. If you don't find anything there pull your wheels and check for rocks around the rotors
Old 12-15-2013, 05:10 AM
djousma's Avatar
djousma
djousma is offline
thanks Will-do
Old 12-15-2013, 08:33 PM
tom18287's Avatar
tom18287
tom18287 is offline
do you have hubcaps? i put stainless simulators on my dump truck. they rubbed on the wheel weights and it sounded like that. take them off i bet you will see the spot where the weight is on the back of the hub cap
Old 12-15-2013, 09:51 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
just throwing out things... best YOU just look at it to find it as the dealership would probably chuckle behind your back
does it coincide with one revolution of the tire or more frequent or less frequent ?
is it possibly something wrapped around a rotating part and slapping something at low speeds, but spinning to fast at higher speeds ?
Old 12-15-2013, 11:38 PM
n3hcp's Avatar
n3hcp
n3hcp is offline
My driver side front wheel makes a noise that could be described as a stone noise. Turned out to be the hub cap itself. Took it off and reinstalled, problem solved...for a while. I have to reseat it every now and again.
Old 12-16-2013, 01:18 AM
tryingaford's Avatar
tryingaford
tryingaford is offline
This same thing happened to me a couple weeks ago. I was rolling slow through the cemetary for my grandmas funeral and everyone is pointing to my front wheel. I rolled down the window and heard what they all were hearing. Clicking from the hub cap area, sounded like a rock in there.
Turns out it was below freezing that day, had just washed the truck that morning, water in the hub cap turned to ice and broke loose in the hub cap and there ya go, just a piece of ice. Made a heck of a racket in there.
Old 12-16-2013, 06:45 AM
djousma's Avatar
djousma
djousma is offline
thanks for the idea's guys. I will look around. I will also take off and reseat the hub cover.
Its been extremely cold up here in Michigan the last couple weeks. As I am sure it has elsewhere too.
Old 04-14-2017, 10:47 AM
F250Kish76's Avatar
F250Kish76
F250Kish76 is offline
Dave
I am having the exact same issue. Pull the tires and cant find a thing. Im ready to pull the dust shields off
Old 04-14-2017, 12:39 PM
djousma's Avatar
djousma
djousma is offline
This is a fairly old thread from me, but as far as I can recall, the cause ended up being debris between the rotor, and the dust shield on the inside of the wheel.
Old 04-14-2017, 12:40 PM
djousma's Avatar
djousma
djousma is offline
I think you are right on with that. Might as well grease the caliper slide pins while you are in there....
Old 04-23-2017, 10:46 PM
mustang9701's Avatar
mustang9701
mustang9701 is offline
some claim its rocks between the dust shields but im never off road. same issue here though, still never found the issue
Old 04-24-2017, 10:21 AM
jvgviper's Avatar
jvgviper
jvgviper is offline
Not very common but can be a bad axle bearing , I've had one axle bearing on a Dodge go bad and never forget the 3 craftmans wrenches I broke which were replaced for free trying to get a nut free
Swiper
2009 - 2014 F150
11-02-2011 03:01 PM
The Anaconda
18
09-07-2011 09:52 AM
fordmerc
21
04-17-2007 12:47 PM
rsyauto
08-20-2006 04:47 PM
jgraff
2004 - 2008 F150
04-08-2005 11:15 PM
Quick Reply: Sounds like stones in the hubcap?
