96 bucket seat just reclines
Hello all. New guy here. I've been looking for an answer and couldn't find one so I thought I'd post a question.
my bucket seat will only has 1 recline position and that is way too far back. when I lift the lever the seat comes up and slides forward. I thought it might be the reclining mechanism so I replaced it, and it does the exact same thing.
what else could be the issue? could an upholstery shop fix this type of thing? I've tried going to junk yards and can't find anything but bench seats. Is there an another option?
Thanks in advance
Thanks in advance
You probably didn't get help because nobody that read your post has ever had the same problem. Perhaps they reasoned that it was easy enough for you to look at some simple mechanical parts and figure it out yourself?
Not being an @$$ here... just saying that you won't always get a reply.
As for a 2001 seat, if you still want to use it then I suggest taking the stock brackets and modifying them to fit your 2001 seat if possible.
With such an uncommon problem, and only having waited one hour after you initial post, that is not surprising...
This is not a team of mechanics at your beckon call... We are all just truck owners that try to help with problems we've had in the past and have found solutions to, in order to make others lives easier...
I'm not trying to be a jerk either, just saying that; you're asking for free advice. You have to have a bit of patience... Someone SHOULD eventually answer... And if they don't its either time for you to figure it out on your own, or take your truck to a pro...
Now... start a post about getting Good gas mileage from a 460, and you'll have more replys than you can count
thanks everyone for your ideas to help. really much appreciated.
I was going to reinforce it to make sure it didn't break again.
Is the cable on the bottom left side of the seat still attached? It should have a nut on the end to adjust how much the seat should recline forward, and it will run through the back of the seat into the arm rest. Wierd I know I just found it on my new bucket seats I installed over the weekend - on the driver side seat only because the passenger folds all the way up and forward.
