97 Expy stuck in 4WD Low- help plz
Hello, new to the forum. I own a 97 4WD and it is stuck in 4WD low. I did not even move the switch to 4WD. Got up this morning and it is in 4Low. With the switch in any position, and no lights on the dash lit up, it stays in 4WL. Tried everything I could think of including trying to shift from Neutral with the brake on. Any help is appreciated as I cannot afford to send to a mechanic. Even if I could get it back to 2WD only that would be a great help. Thank you to anyone who helps, I greatly appreciate it.
Jeff
Cincinnati, OH
Jeff
Cincinnati, OH
Also, if you get under the truck and remove the shift motor from the back of the transfer case, you can manually move the cam out of 4WDL.
cotten616
1997-2006 Expedition & Navigator
13
02-16-2021 08:35 PM
