98 f150 shut down/no start
Gentlemen,
I have a serious issue and need help. Vehicle is stranded on the side of the road (safely) and here's what happened. Driving (normal) 1/4 mile away from the house, motor shut down. Pulled off, tried restart. Motor turns over normally and all gauges work (temp/oil/volt). The only weird thing is that the O/D light on the end of the shift selector stays on even after pushing it on and off. I plugged in my OBDII reader and it will not link with the system. Yes... the ignition is on Is this indicative of a fuel, computer, electrical issue? or all the above. Worst case scenario is i have it towed to the shop tomorrow and they diag it. I don't have the proper tools to diag this Thanks for the help all!
Tex1986
Tex1986
bubbles was lack of fuel. EIther you have a fuel pump problem that causes pump to quite now and then, or you had a slug of water / ice in the line that changed / melted overnight. If it happens again, or even daily test... when you turn the key every morning, do you hear the fuel pump run for a second and build up pressure ?
This would be the first time it's ever done this. I live in Tampa FL, so there's no ice. At least from weather conditions. Yes, I do hear the pump run. I went for a drive this morning and it drove fine and no issues. The thing that bothers me is that when the truck shut off, the OD light came on and stayed on.
tubby12729
09-04-2012 09:41 PM
leadfoot7
08-23-2012 03:49 PM
mnf150
06-27-2002 05:25 PM
