EX eating hub bearings faster than I drive it. What could it be? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 12-12-2013, 07:18 PM
saz2686's Avatar
saz2686 saz2686 is offline
saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.
I have replaced my hub bearings on both driver and passenger side many times. I realize it must be something more to the problem. I know others grease their hubs so often as this is a common issue. Not like this though! It is to the point It will toast a hub bearing every hundred miles. They fail as fast as I replace them! Drivers side is currently toast again. Replaced as follows and getting worse.
Passenger side 147K miles - Duralast / Autozone
Drivers side 150K miles - Ebay / unknown brand
Drivers side 160,700K miles - Pep boys / unknown brand
Drivers side 164,040K miles - Timekin / Autozone
Passenger side 165K miles - Duralast / Autozone
Passenger side 165,465K miles - Timekin / Autozone
Passenger side 165,600K miles - Timekin / Autozone
Drivers side 165,700K miles - Current mileage / currently failed.
I don't keep my hubs locked. The U joints spin freely while hubs are not locked. This is getting old fast. I am ready to fix it! What could be the issue?
Old 12-12-2013, 07:47 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Getting dirt in the abs sensor hole on install??
Old 12-12-2013, 07:50 PM
LivingLarge's Avatar
LivingLarge LivingLarge is offline
LivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputationLivingLarge has a superb reputation
Scott, I've never heard of this, my first Ex went at 154k on originals and I replaced with OEM and sold truck with 228k no problems.
My current Ex just had passenger side go at 125k, replaced last week with OEM will see how long they last.
Take it to Ford or buy the OEM they now have 24 months unlimited mile warranty.
Old 12-14-2013, 12:46 AM
h20_guy33 h20_guy33 is offline
h20_guy33 is starting off with a positive reputation.
I had this issue when I bought mine. The PO had replaced the factory hubs and left out one of the spacers on each side. Brand new timkens were shot in two weeks after I replaced them because I didn't realize the spacer was missing when I swapped everything out.
Old 12-14-2013, 01:21 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
There is definitely something wrong there. Are you referring to the locking hub bearings or the main wheel bearing? I wouldn't fix it again until you get to the bottom of it.
Old 12-14-2013, 01:31 AM
hav24wheel's Avatar
Quote:
Spacers?
The ones that go on the axle shaft inside the hub? That's the only spacers I can remember.
Old 12-14-2013, 02:13 AM
rockcrawler_101 rockcrawler_101 is offline
rockcrawler_101 is gaining momentum as a positive member of FTE.rockcrawler_101 is gaining momentum as a positive member of FTE.
your ball joints ok? might be getting the wheel bearing worn confused with worn out ball joints. How is your alignment? Might be off where your putting a ton of stress on the wheel bearings. This is strange and have never heard of anyone going threw them so fast.
Old 12-14-2013, 08:35 AM
saz2686's Avatar
ABS comes with the sensor installed, no dirt Inside. Brent, I am talking about the main wheel bearing sealed unit. Ball joints are tight, replaced at 136K. I thought it might be something to do with those spacers. I got the round plastic vacuum part first, then a round metal washer, then hexagon metal washer, and another round metal washer before the c-clip. It could be installer error - me. Here is how I have done it since the first one
http://www.ford-trucks.com/forums/10...l#post10232170
Oh crap I think I just figured out my fatal error!!!!!!!! looking back at that thread I realized the plastic washer goes in BEFORE the wheel bearing assembly. I have been installing that piece on the outside .
Should have followed my nice post from the first time. I shall take it apart and report back after another try
Old 12-14-2013, 12:21 PM
Sammie (Christina) has already addressed this common problem, I don't know where the post is.
Old 12-14-2013, 12:25 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Good call on this one.
That is why I always used guzzle's page for removal and install. He even has the torque amounts needed to put everything back together.
I know EXv10 and others don't use a torque wrench, but some of us do!
Old 12-14-2013, 12:46 PM
hav24wheel's Avatar
Quote:
A what? Some of us have a calibrated elbow.
Old 12-14-2013, 01:04 PM
Quote:
Yep, that's right. After you tighten bolts all day every day 8 hours a day for 10 years you rarely need one. I did use them on head bolts and a few other things.
Old 12-14-2013, 02:05 PM
saz2686's Avatar
Now I am confusing myself. No way all 4 pieces would fit before the c-clip. I don't remember even though I have done it enough times. Maybe it has something to do with the hub locks (Warn). +1 I don't own a torque wrench.
Old 12-14-2013, 02:13 PM
Quote:
You don't need a torque wrench.........here;
Old 12-14-2013, 02:21 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Quote:
Same here , rarely use my torque wrench . After wrenching for a living for almost 20 years , you get a feel for things
2013 4x4 hub problem sealer700 1999 to 2016 Super Duty 6 11-28-2015 08:36 PM
2002 F350 bad wheel bearings JohnyQ 1999 to 2016 Super Duty 5 04-02-2015 10:05 AM
Bearing Hub Replacement Question Submarine Docker 1999 - 2003 7.3L Power Stroke Diesel 8 01-07-2015 02:36 PM
Front axles bascars 1999 - 2003 7.3L Power Stroke Diesel 17 07-29-2014 02:26 PM
I can't get the Mile Marker lock hub in the right side junkrider 1987 - 1996 F150 & Larger F-Series Trucks 3 11-07-2009 12:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
