c6 short tail shaft - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
c6 short tail shaft
Old 12-12-2013, 05:36 PM
flaboy1979 flaboy1979 is offline
flaboy1979 is starting off with a positive reputation.
c6 short tail shaft
I need to swap out my tail shaft I need a short tail shaft housing and output shaft two wheel drive thankyou charleywhite1979@gmail.com
Old 12-12-2013, 08:42 PM
quesey's Avatar
quesey quesey is online now
quesey is gaining momentum as a positive member of FTE.
email sent
Old 12-14-2013, 08:32 PM
I found one locally that's to everyone who responded
Changing from 351W with baby C6 to 429 with C6. Doug Lorimer 1968-2013 Full Size Vans 1 08-07-2016 08:03 PM
C6 TAIL SHAFT customsport Clutch, Transmission, Differential, Axle & Transfer Case 1 10-02-2015 04:24 PM
3.03 Output shaft swap gravydude 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-02-2015 12:31 PM
Crossmember Problems? FloridaPhil Clutch, Transmission, Differential, Axle & Transfer Case 2 06-06-2012 06:39 AM
short tail shaft to a long tail shaft Opiewan Clutch, Transmission, Differential, Axle & Transfer Case 6 09-28-2003 10:15 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
