thermostat - Ford Truck Enthusiasts Forums
thermostat
Old 12-12-2013, 01:03 PM
76ClydeF100's Avatar
76ClydeF100 76ClydeF100 is offline
76ClydeF100 is starting off with a positive reputation.
thermostat
I have a newly rebuilt 1976 F100 with a 360 engine that just got rebuilt. My mechanic that did it was a real but about doing stuff and didnt do all the things that he said he was going to do. Anyways my temperature gauge on my dash does not work and I would like it to. The oil pressure gauge works well and everything else minus the fuel gauge (thats a differemt more severe job). I just want it to work and work right but I dont even know where to start. Im learning on the job on how to work on vehicles...im a house flipper/carpenter/teacher by trade so I can figure most everything out just need help going in the right direction. Thanks in advance
Old 12-12-2013, 02:13 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Ground the sensor wire to the intake, the gauge should peg HOT. If it does you need a new sensor.
If it doesn't move at all you need to start tracing the wire back looking for chafing or a break.
Josh
Old 12-12-2013, 04:05 PM
I don't even know where the sensor is. Basics my man basics.
Old 12-12-2013, 04:13 PM
Bullitt390's Avatar
About the middle of the intake right behind the distributor. Just one wire goes to it.
Josh
Old 12-23-2013, 09:22 PM
I found it. The wire goes to the distributer...what do I do to figure this out? Do i get another wire and touch it to it or what?
Old 12-23-2013, 09:33 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
Originally Posted by 76ClydeF100 View Post
I found it. The wire goes to the distributor...what do I do to figure this out? Do i get another wire and touch it to it or what?
The water temp sensor doesn't go to the distributor. It's just wrapped in the same harness.
It's an OEM connector, right? Looks like and "L"? Ground it to the block with either alligator clips, a section of wire, or unfold a paper clip and use it as a bridge. Have a helper observe the temp gauge while ya ground it.
Old 12-23-2013, 10:15 PM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
Just behind the hole where the distributor goes through is the sensor. It should be a hex shape (for a socket) and have a small stem sticking up.
Sorry for the bad pic, only one I could fine quickly...
EDIT - Found another pic.
Old 01-13-2014, 12:57 PM
Found it and it for somereason has started to work and work well now...dont know what I did and thanks for all the help everyone
Old 01-13-2014, 06:14 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Our trucks need a wiggle, jiggle once and a while to keep em running... LOL
1968 f100 Gauges Issues 68Rookie 1967 - 1972 F-100 & Larger F-Series Trucks 21 10-27-2016 03:57 PM
All gauges dont work Michaelkrieger 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-25-2016 08:39 AM
No interior lights or turn signals after motor swap tlrtucker 1973 - 1979 F-100 & Larger F-Series Trucks 18 11-29-2015 04:24 PM
Gas and Temperature Gauge Issues JD_F100 1967 - 1972 F-100 & Larger F-Series Trucks 26 08-31-2014 11:26 AM
Newbie: Oil pressure gauge install lightningdan 1999 - 2003 7.3L Power Stroke Diesel 20 01-19-2012 11:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
