Exhaust smell in the cab - Ford Truck Enthusiasts Forums
Old 12-12-2013, 09:16 AM
PlayersZ28's Avatar
PlayersZ28 PlayersZ28 is offline
PlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant future
Was cold this morning, -15c, and I remote started the truck and then left home about 5min later. I could smell exhaust in the cab. I read some of the other threads about this.
How can I tell if it was doing a regen? I have an Edge Insight. Is the a parameter I can display to know the regen was active?
Old 12-12-2013, 09:34 AM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Steve. On the Insite when in regen at top of screen you will see a red R if in regen. the parameter you can have on screen is dpf soot. when it hits. about 2.67 it will trigger a regen. you will also see that light come on. when it is done regen about 10 miles the light will go off,but if you watch soot it will still keep lowering for about 3 miles.
Old 12-12-2013, 09:59 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
A regen will not start until the oil is 150F.
Old 12-12-2013, 10:01 AM
Randy_270's Avatar
Randy_270 Randy_270 is offline
Randy_270 has much to be proud ofRandy_270 has much to be proud ofRandy_270 has much to be proud ofRandy_270 has much to be proud ofRandy_270 has much to be proud ofRandy_270 has much to be proud ofRandy_270 has much to be proud ofRandy_270 has much to be proud ofRandy_270 has much to be proud of
You're truck won't go into regen mode unless it's at a certain temperature I'm pretty sure. Your problem is most likely a loose fitting on your exhaust. If you lay under your truck and look up where the down pipe is with a flash light you will see a brass fitting way up near the top of your down pipe. You need to push yourself up with your right arm and streatch all the way up with your left arm to reach it and tighten it. If you have short arms you'll need a tall friend to help, or better yet bring it to a dealer/shop. It's a quick 30 second fix if you can do it yourself. I cant gaurantee that this will fix your problem but this is usually what the problem is for the exhaust smell in the cab.
Old 12-12-2013, 10:25 AM
PlayersZ28's Avatar
OK, wasn't a regen then as the truck was nowhere near that warm.
I'll see if I can get up in there to check that fitting today. Truck is in the back of my shop making a big mess as the snow melts off it
Old 12-12-2013, 10:48 AM
Randy_270's Avatar
Good luck. Iirc it's a 16mm wrench to snug it up.
Old 12-12-2013, 07:22 PM
EO2SeaBee's Avatar
EO2SeaBee EO2SeaBee is online now
I'm Deplorable
EO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputation
I've experienced this problem a few times after a remote start as well. In my case though, the wind was blowing out of the north, carrying exhaust fumes from the pipe into the defrost intake beneath the windshield, since below a certain temp, remote start automatically starts the defrosters. WHen the wind is still or coming from another direction, I don't have this issue. Something to consider?
Old 12-12-2013, 07:39 PM
kper05's Avatar
Yeah, all depends if it's a "real" diesel smell or the stinky post emissions diesel smell.
I know DEF doesn't come into play with a cold start but the exhaust still has the modern emissions diesel stink to it.
Old 12-12-2013, 10:40 PM
LaxPlaya21's Avatar
LaxPlaya21 LaxPlaya21 is offline
LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.
I have definitely smelt the DPF burnt exhaust, and the smell of ammonia... very faint but it happens. Only when I am stopped at a light. It is almost like a back draft.
What I am not used to in the cold weather is all of the water vapor coming out of the exhaust, makes it look like a gasser!
Old 12-12-2013, 10:50 PM
EO2SeaBee's Avatar
I'm Deplorable
Next time you smell it, see if you can tell the wind direction. If it is coming from behind your truck, then the wind is likely carrying it into your HVAC intake. You're more likely to smell it in the winter than in the summer, because you seldom - if ever - use recirculation with heat/defrost as you would with with max A/C.
Old 12-12-2013, 11:05 PM
kper05's Avatar
For the mornings I start my truck and let it high idle for a few, I turn on the defrost + floor heat option and then I can turn on recirculate.
Recirc will stay on for about 7-8 minutes before it turns off on it's own.
That keeps the exhaust out of the cab.
Of course this is because I have to walk out to my truck to start it.
Old 12-12-2013, 11:14 PM
EO2SeaBee's Avatar
I'm Deplorable
That's true. I was only considering automatic operation of the climate control via remote start. Manual operation would help keep the fumes out though by using recirc. I don't mind the smell in small doses. It reminds me that it's a truck. I prefer the smell of burned diesel over the smell of unleaded any day.
Old 12-12-2013, 11:21 PM
LaxPlaya21's Avatar
Quote:
It is hard to get that smell from our truck. Seems to be either a clean sweet smell, a burnt DPF smell, or a eye watering ammonia smell. I too miss that hint of cleanly burnt diesel smell like on my old 6.0. Forget a tuned unrestricted truck... that much diesel exhaust could give me cancer and make me puke in the same whiff!
Old 12-18-2013, 04:21 PM
FordServiceCA's Avatar
FordServiceCA FordServiceCA is offline
Official Ford Rep
FordServiceCA is starting off with a positive reputation.
Hi PlayersZ28,
It sounds like the technicians at your local dealership would be in the best position to assist. Please send me via PM your VIN, full name, best daytime phone number, odometer reading, and servicing dealer so I can do some research for you.
Bianca
Old 12-18-2013, 04:32 PM
PlayersZ28's Avatar
Quote:
Originally Posted by FordServiceCA View Post
Hi PlayersZ28,
Bianca
Thanks Bianca, haven't noticed it the last couple of days so maybe it was related to the wind and the remote start. I'll keep a nose out for it and see if it happens again.
Diesel Fumes in Cab during Regen buckmasters 6.7L Power Stroke Diesel 70 12-24-2016 03:54 PM
How does regen work? kcwolf200 2017 Super Duty 30 12-08-2016 01:25 PM
Frequent Regens - Clean the DPF? Aaron Green General Diesel Discussion 21 03-09-2016 12:20 AM
Exhaust smell during Regen. Rudiak 6.4L Power Stroke Diesel 7 11-09-2015 08:14 PM
Grinding sound from engine compartment after regen. PumpDoctor 6.4L Power Stroke Diesel 4 06-16-2009 07:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
