I could use some help
#32
I have good news and bad news.
The good news is I found one bracket still attached to a replacement door that I have. Bad news is that I only have one. It's the left side. You can use this one as a pattern to build the right side. They're mirror image of each other.
If you don't find a set, the one that I have is available. PM or email me.
#34
I misunderstood the post. Here's the rear door latch assembly from a 48-52. 53-36 may be the same (or at least the same principle).
This latch assembly will be even harder to find by itself than the guide brackets. You may have to buy a door just to get the latch assembly.
This latch assembly goes inside the right rear door.
EDIT:
This release latch goes inside the upper right corner of the left rear door.
EDIT:
#35
I am not sure if the 48-52 are the same as 53-56 either.
#37
Received 4,130 Likes
on
#38
For what it's worth, I just bought a '60 panel and while a few of the latch mechanisms are un attached or inoperable, mine look exactly the same as those parts. Maybe Bill will fill us in if they are the same. Just thought that could possibly broaden your search all the way to '60, if applicable.
#39
#40
on
#41
Thank you very much!
#42
on
#44
on
Top latches are side specific, bottoms are the same. Unfortunately it's one of the top ones I've misplaced. I never expected that anyone would have had a need for these and that is why one of the rods are missing; I needed it for another project and the rod was the right diameter but the latch has got to be kicking around here somewhere hopefully.
