steering questions - Ford Truck Enthusiasts Forums
steering questions
Old 12-11-2013, 09:35 PM
76F250High's Avatar
76F250High 76F250High is offline
76F250High is starting off with a positive reputation.
steering questions
So I am wondering what steering box I have installed. Everything I've read is the stock box has a 3 bolt mounting pattern. However the box has 4 bolts and is mounted on a bracket (I'll try linking my photobucket at the bottom). I'm trying to figure this out as the pitman arm gets rubbed when I make a full left turn. My 76 F250 is sitting on 35x12.50's. I've heard talk of crossover steering to upgrade the steering. Now I'm wondering if I have a good box already installed how difficult it would be to finish the mod to crossover? From the axle code looks like I have a Ford? front end (had to re-look at vin decoder the right way not sure what front end I have cause it only says Ford). Looks to me like I could unbolt the "drag link?" from the knuckle, and swap the attaching parts between the driver and passenger side? It looks like it's a spacer on the passenger side that holds up the brake line could be removed with fairly little problem. I don't have pictures of that right now. So here goes my attempt to upload pictures of the steering box.
Old 12-16-2013, 07:52 PM
76F250High's Avatar
Nobody? Through some digging I discovered I have a Dana 44, closed flat top knuckles.
Old 12-16-2013, 09:30 PM
PA74F250's Avatar
PA74F250 PA74F250 is online now
PA74F250 is starting off with a positive reputation.
I can't say I've ever seen one like that but I know where it would be going. I did the 78/79 4wd box swap and it was worth it for clearance and ease of steering.
Old 12-16-2013, 09:34 PM
PA74F250's Avatar
Also I don't see how that would ever work for crossover steering the way the pitman arm comes off the box. A 78/79 Dana 60 is easiest to do crossover which is what I used but they cost a lot. You can do it with a d44 but it's a lot more of a pain plus you would need to lift it some for the crossover to clear the springs.
Old 12-16-2013, 09:38 PM
PA74F250's Avatar
Here's a 2nd one I built same as mine for example. I don't have any closer pics on my photobucket at the moment.
Old 12-18-2013, 08:31 PM
76F250High's Avatar
Thanks for the reply. I was thinking I might be able to get it to work for cross over if I take it off the bracket and mount it to the same outside part of the frame. This would put the pitman arm under the frame. However looking at spring clearance I can see what you mean about lifting. I may look into the inverted T setup, or just get a 78/79 box for clearance and not worry about trying to change a whole bunch of steering components since I'd have to move the current box anyway. I plan on trying to dig as much of the grime off that box as I can to see if I can pull any part numbers or other identifying info off of it.
Old 12-18-2013, 08:59 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Quote:
Originally Posted by 76F250High View Post
Nobody?
I would say that setup is off of a 1972 - 1977 Dodge. I know the first Gen. people (me included) use that setup to get rid of the frame cracking problem. It might be worth something to the right person.
http://www.dieseltruckresource.com/d...2-t301769.html
Old 12-19-2013, 12:01 AM
76F250High's Avatar
Quote:
Steering Gear Retrofit in my 92 - Dodge Diesel - Diesel Truck Resource Forums
Thanks for the reply with a bit more info as to what it might be. If I could find a way to keep the 35's and not rub the pitman arm I'd stick with this setup. Once I get done replacing some seals to shore up some of the leaks under the truck I might take it to the local off road shop to see if they can do anything for me.
Superduty bed swap pictorial BioBurner 1999 to 2016 Super Duty 49 12-12-2016 02:57 PM
AC Compressor Mounting Woes, belts, etc. *pics* KrenzyRyan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 10-05-2013 07:37 PM
My New Project - 1980 F100 - Pics KrenzyRyan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 36 09-21-2013 06:47 PM
Papa got brand new shoes! Pacman51 6.7L Power Stroke Diesel 45 04-17-2013 11:04 AM
Another leveling kit/35" tire install thread 2000silverbullet 1999 to 2016 Super Duty 33 09-15-2012 03:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
