water out tailpipe
water out tailpipe
Hi,need some help.My 48 f1 flathead 226 has water dripping out of exhaust when revving engine.Already changed head gasket, copper one ,milled head ,magnafluxed head no cracks ,no thermostat installed.Was pushing out overflow tube now its not. Happens everytime it is run hot or cold small puddle on floor, droplets on acceleration, some smoke, block looked good no visible cracks ,Need your input please
IT does not smell of antifreeze out exhaust,I have a thermostat with holes in it,I have put 150 miles on truck since install of head gasket,looks like steam out exhaust,its more than a bit of moisture I started it 3x today and drove it 10-15 miles each time,every time I started it small puddle out exhaust on floor even when warm?
If not loosing coolant , likely just steam from combustion . My 53 will leave a puddle when I start her and let her run in the garage( not heated ) when it is cold . A proper thermostat will help . But even with a proper thermostat my 53 ( Pontiac ) straight 8 makes a puddle out the tail pipe .
Not a good idea to post the same question in two places...
1. What are your compression values?
2. Are any of your plugs unusually clean? A cylinder pumping water will be scoured clean.
3. Does it do this if you leave the radiator cap off?
4. Did the cold weather come before your long trip, and you turned on the heater for the trip?
Sorry about posting in 2 places,seen a thread in another place,my mistake.There is no heater in truck,heater hoses are run back to engine,need to do compression test,plugs 3-4 were white that's why I changed head gasket,need to check plugs again,What should I look for with the cap off,I am filling radiator just to fins in neck,water pump starting to make a slight noise,Thanks sorry for double post
With no cap on (or on loosely), there should be no cooling system pressure. Not many cracks will leak water with no pressure, depending where the crack is. If it's in a cylinder bore, it still might, but at a lower rate. You can watch for bubbles with the cap off too.
I agree with above, tho, until the engine is fully warmed up, and the exhaust system warmed up, you're going to be getting condensation from the exhaust. I see you're in NY, I presume it's pretty cold there now? It could take 15 minutes driving to get all of it out. (You should put your location in your Profile, in UserCP)
