water out tailpipe
Old 12-12-2013, 01:47 PM
train2's Avatar
train2
train2 is offline
OK I moved to south Carolina have not had chance to update.Radiator cap dennis carpenter 4lb brand new,The reason thermostat is modified when installed building up too much pressure even with new headgasket.Drove 6 miles with cap in loose notched position came home heard air escaping from cap,removed cap and saw antifreeze circulating on top of fins with some bubbles not a lot,truck is running rough and using more gas than usual,I have logged 175 miles since head gasket,Its 60 degrees right now truck is warm but you can see the exhaust when revving,Thanks
Old 12-12-2013, 04:09 PM
obscurity's Avatar
obscurity
obscurity is offline
I was always under the impression that a little water out of the tail pipe is correct after the combustion process. Not bulk water mind you. I you watch a new car run it will drip water out the tail pipe.
Old 12-12-2013, 04:19 PM
train2's Avatar
train2
train2 is offline
Its a 6 inch puddle every time I shut it off and re start it pulled all plugs, first 4 whiter than last 2 ,Spun engine with no plugs no water or anti freeze came out going out and purchase thermostat a 160 since I have no heater and live in the south?Thanks
Old 12-12-2013, 04:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Still no sign of water in the oil?
Is the copper head gasket solid copper, or a sandwich of composition material and copper sheets?
Old 12-12-2013, 06:44 PM
train2's Avatar
train2
train2 is offline
Its all copper. Orders to fit milling of head
Old 12-12-2013, 06:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't know what you mean? Milling the head doesn't mean you need a different head gasket. Copper head gaskets are notoriously hard to seal. Go back with a FelPro or Best gasket, I bet this stops bleeding.
Old 12-12-2013, 07:09 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
I use to sell copper gaskets in different thicknesses for Datsun engines .Being an overhead cam ,after milling the head , sometimes you had to compensate for the amount removed . On this app compression issue or head fitment issue ? If a copper gasket is a must , Hi Tac or Copper Cote is needed to seal properly .
Old 12-12-2013, 07:23 PM
train2's Avatar
train2
train2 is offline
Thank you that is what I meant, by ordering gasket to fit milled head ,it was sprayed with copper coat, also,the first time it was a felpro gasket the problem was worse,Thanks
Old 12-12-2013, 07:35 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
If loosing coolant , heads milled , new gaskets ,proper coolant flow ... How is your block ?
Old 12-12-2013, 07:50 PM
train2's Avatar
train2
train2 is offline
Block looked. Fine from what I can see. Engine still in vechicle
Old 12-12-2013, 08:00 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Heck my ex wife looked fine also ! She had issues
Old 12-12-2013, 08:03 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Sorry ... If loosing coolant out the tail pipe , It has to be coming from somewhere . Heads proper? Proper gaskets ? Proper install ?Proper coolant flow and temp? Look at the block .
  #28
Old 12-12-2013, 08:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If it isn't the head gasket leaking, I'd vote for a crack in a valve bowl, probably between an intake and exhaust, leaking into both.
A pressure test on the cooling system will tell you quickly. AutoZone and others loan the tool to do this.
  #29
Old 12-12-2013, 08:52 PM
train2's Avatar
train2
train2 is offline
OK I WILL TRY PRESSURE TEST TOMORROW. WHAT AM I LOOKING FOR. TOTAL. DROP IN PRESSURE. HOW LONG DO YOU LEAVE IY ON?
  #30
Old 12-12-2013, 09:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Start it up (cap off) and warm it up, shut down, put the water level up to some level you can identify easily. Pressure up to 5 psi. Leave it on for an hour.
If it won't hold pressure, look for water leaking. Be careful, because water may get forced into the cylinders, and cranking it may hydrolock it. So pull the plugs and see which cylinders squirt.
Quick Reply: water out tailpipe
