Basic differences between F150 & F250??
The basic differences between the light duty trucks (150, 250 ld and 150 7700) and the Super Duty Trucks, is the super duty's have solid alxes front and rear (where applicable) heavier springs, sway bars front and rear, full floating 10.5 or heavier rear axles, heavier wheels, stronger frame, slightly stronger automatic, much stronger manual transmissions, and much bigger brakes.
Jimmy,
It is an XLT xtra cab 4X4 with 4.6L, off road package, and factory tow package. I'm not sure about the other stuff. I haven't really gotten into it as yet.
aldridgec,
So, the basic differences between the light duty trucks (150, 250 ld and 150 7700) is what?
Thanks
sp
aldridgec,
Thanks
sp
The F250 LD and newer F150 with 7700 package can carry more weight and tow a little more as well. The springs and brakes are heavier on them.
Your truck will pull your trailer but your 4.6 will be working hard.
I have a 5.4 F250 LD, my neighbor had a 4.6 F250 LD and we both pulled the same heavy duty double axle trailer. He claimed he never pulled it much faster then 65 mph. With the 5.4, I had no problem pulling it up to 80 mph and cruising in overdrive. I had higher gears then he did but my 5.4 didn't seem to mind.
The frontal area on your trailer is what is going to kill your performance along with that 6300 lb.
How much and how far are you going?
Dan,
I'll pull the camper about 12 times per year. I just pulled it to and from Dover Delaware from home(Connecticut) and it didn't seem to mind. I use a weight distribution system and most of the time I have to look in the mirror to see if it is still there. I just don't want the truck to start falling apart on me, know what I mean?
Steve
Steve
Originally posted by sep
Jimmy,
aldridgec,
Thanks
sp
Jimmy,
aldridgec,
Thanks
sp
THe 7700 has extra cooling, bigger battery/alternator, more front and rear spring capacity, bigger semifloating rear axle and heavier wheel/tire combo. All 7700s have the 5.4, but not all have the 4r100 like they should.
The 7700 pkg came out in 2000 after the SD's were introduced. In 1999 they were still called (LD) F250's. You can use the term 'light duty' loosely, I had an 01 7700 and it was a heavy duty truck in my opinion. They don't feel like a regular 150 at all.
Just as a heads up:
If you do decide on the LD or 7700, and do a lot of the maintenance on the vehicle yourself, you have to be careful about some of the parts you get. I've not experienced it yet, but it appears some of the parts houses don't know what a 7700 or LD is and will try to give you regular F150 parts. This seems to apply more to the brakes and axles, than anything else. It's that darned 7 lug pattern and the 10.25" rear being on these trucks that just throw people off.
Love the truck, feels solid and I don't have the larger truck payment (like $25 more a month, but tack on gas, insurance, and licensing and it's close to $75).
Good luck
-Kerry
Good luck
-Kerry
Typcially a heavy duty truck has full floating axles. Doubtful I could ever break the 1.5 inch axle shafts in the 7700, but the Full floating seems to be the single distiguishing factor.
Chris
