1986 f150 dually project
My 90 has a service bed on it and duals would sure make it more stable. J C Whitney used to make a kit that had a spacer and real long nuts to put duals an dang near anything, but there are drawbacks. We had a set on an 80 F-250 and they stuck out really far, even wider than a regular dually. On a semi-floating axle, like your F150, they put a HUGE strain on the axle flange. Just bumping a curb could break off the axle. If yours is a 2WD I would suggest a dually axle transplant and some short tires to match the fronts. If its a 4WD, you have a big job ahead of you. I wonder if anybody makes custom wheels, like 2 wheels fastened together side-by-side?
on
don't do it.if you want a dually,get into the HD platform first.just a few parts of a proper dually convert would greatly surpass the value of your truck (no offense intended) and you'd be left with something without any real use and costly to operate.you'd get all the cons of owning a DRW while gaining none of their pro's.
There were some guys around here that did 8 lug rear axles on 150 trucks. They were old beater cord wood trucks and they just hacked them together with a welder. Even the best one's didn't work cause they beat the front ends out in short time. Donor frame may be the best way to get something unique and functional. Just plan on keeping it forever and don't plan on selling it for anything close to what you have in it. There is a buyer out there somewhere for everything and I might get surprised on this. If this is a dream and you have the resources to do it right, go for it. This forum will be here to help you work out the bugs. Build it and be proud.
Josh Keller
04-07-2014 07:20 PM
78LOTLIZARD
05-07-2010 09:33 AM
IDIDieselJohn
12-29-2009 08:59 PM
