51 F5 Brake Help!
51 F5 Brake Help!
Hey guys, I have been working on the brakes of a 51 F5 truck. The front wheel cylinders looked fine so I left them. The rear axle seems to be out of a late 50's or 60's F600 and I replaced all 4 of the rear wheel cylinders. The master was fine but the Hydrovac booster was leaking and I replaced it with a new one out of a 58 F350 which is slightly larger but the same working unit as the original, it actually fit the original brackets. Now Im having an issue where the wheel cylinders will not release. I have checked the play in the master cylinder push rod and it is fine. What am I missing here?
DieselBeast01
24
01-26-2021 03:41 PM
400inatruck
09-05-2012 09:50 PM
