Help with after market Engine block heaters please
Help with aftermarket Engine block heaters.
My dad has a 1950's Ferguson MF 25 diesel. I would like to install a plug in 120 volt block heater. No easy access freeze plugs. Was thinking about external oil pan heater but I have desided a coolant heater would heat the engine better. How well do lower radiator hose block heaters work??
They work fine and are easy to install. Just have to cut about an inch out of the lower radiator hose for the heater. They are essentially the same element as in a block heater, just in the hose. Look at your hose though, its recommended to have a section running vertically to the waterpump. IIRC, lots of older tractors have the bottom hose running mostly horizontal from the radiator to the pump.
variations in lower radiator hose sizes
Very good point on the variation of radiator hose sizes!! I will have to get the exact size of the hose probably down to an eighth of an inch or even a sixteenth. I am noticing some differences in wattage. I know the higher rated wattages would probably heat up faster. I will have to do some shopping around. It is a 1.8 liter diesel engine not much to heat up
Well being the tractor is in Michigan and i am in Indiana. I am having horrible trouble finding out the lower hose size. I was going to install it on the tractor for my dad as a Christmas gift. Its his first and only diesel tractor out of 5. He likes it a lot for the steady torque and furl economy.
Rusty_S
19
04-05-2019 07:58 PM
Quinny
1983 - 2012 Ranger & B-Series
11-02-2005 08:42 AM
