Harley Davidson headlight swap
I have a 2005 F250 that I'm going to swap some HD headlights in. So far the cheapest I've found them is on Amazon:
Is that the right one? There's lots of options for the Harley lights and these are the cheapest, just wanted to double check these are correct. Also, there are some that have a pigtail included, I don't need the pigtail right?
I want to eventually do a HID conversion. I know there's a lot of debate on whether or not they should be used without projectors or whatever, but I just want to make sure I get a good kit.
I don't really know jack **** about HID lights so that's why I'm asking. Is this kit any good? Does it come with everything I need to effectively not muff anything up? If I do HID's in the headlights I'd like to do some HID's in the foglights as well, and LED parking/turn signals. Thanks for the help.
FORD F-SUPER DUTY/F250/350 (HARLEY-DAVIDSON MODEL) PAIR HEADLIGHT 05-07 NEW : Amazon.com : Automotive
Okay thank you. I just wanted to make sure these are the same. I see there's a lot of different options for seemingly the same thing but they're from different venders I guess so wanted to check and make sure it's not something weird haha.
And with the HID's I wanted to see if that had everything needed to not overload the system and stuff cause as far as I know you can't just throw a HID bulb or whatever in there without some other parts right?
Most of the headlight assemblies are the same. Unless you get an extremely off brand then that could cause fitting problems. The only thing that is special about the HD lights is that they are "black" lol. My dads Outlaw edition came stock with black headlights.
Here we go again with the last time i checked..... When you bought the HID kit it came with the invert-er box or whatever its called to keep the lights in check and to keep from burning anything up.
You really should do some research on hid lights and "kits" before you buy something. Sticking any bulb brighter than oem, especially hid kits, will just blind oncoming cars. Big difference between kits and projectors. Projectors are set so they have a cutoff so not to blind oncoming cars. They are also much brighter.
Here is some good info:
The Retrofit Source online: headlight upgrades for all applications
My recommendation is try a relay harness for the stock bulbs then if you dont like the output still consider doing an HID projector conversion. I just did the plug and play kit and although i have much better output i had to aim the lights way down to to blind people and the output would be much better with projectors. If you do want a plug and play kits go to DDM tuning they are cheap and decent kits, that's where i got mine.
