Edge CTS Blue "X"
Edge CTS Blue "X"
In the last thread I created about an update for the Edge CTS, a few people commented that after the update they lost the red R during regen and now had a blue X in its place. I finally figured out what the blue X is for.
I noticed the blue X this morning and curiosity got the best of me. Turns out it is a maintenance reminder. When playing around a few weeks ago I had set an oil change reminder and that is what it was trying to tell me. Once I reset that, the blue X was gone.
By the way, Edge just came out with another CTS update that added a few cool new features. Maybe if I get bored later I will true to load the update.
Latest update seems to be good so far. Red X is back during regens, and additional screens are pretty slick as well.
Also, no more goofiness after a remote start. You no longer have to touch the screen to get it to come on after remote starting. It's on when you jump in and does not restart when you insert and turn on the key.
Well, the % grade PID is about useless on the XLT trucks at least.
On flat ground, it has been reporting anywhere from 4% to 8% grade so it's a bit confused and jumps around when not moving.
I have the basic information center so I don't have the pitch/roll like the LCD screen has but I was curious if my truck knew but didn't report it to a screen.
Doesn't seem like my truck knows.
I like the latest update from Edge.
It was end of January if I remember right.
I found after the update that the Red 'dot' for regen was coming on later than original; IIRC when the 4th Temperature sensor goes above 1150 it is on; when below 1150 it is off.
I actually have the regen status PID picked for lower right of display screen I use and it comes on pretty much in sync with a message on the dash; and much sooner than the Red 'dot'. I might add that prior to the update the red 'dot' never matched the monitoring of this PID either and would be slowly flashing from 'on' and 'off' toward end of regen sometimes.
I was hoping the manual regen was possible while running down the road, which it isn't; however, it does work on my 2012 at idle.
Bob
Bob
Bob
Bob
Interesting: Do you know where the 4<sup>th</sup> temperaturesensor is located physically and do the other three EGT sensors go above 1150degrees during Regen.
