5.4 Cold weather transmission sticking - Ford Truck Enthusiasts Forums
Old 12-10-2013, 10:16 AM
coleaukee coleaukee is offline
coleaukee is starting off with a positive reputation.
When I fire up my rig when its below ten degrees, even in neutral or with the clutch depressed, I can feel the motor trying to engage something in both the stick and the clutch pedal. It is enough to make the motor sputter and die. If I hammer on it for a few seconds i can feel it breaking up then it runs great. Any suggestions on an alternate gear oil that I wont lose protection with. Any ideas will be great!
Thanks!
Old 12-19-2013, 11:12 PM
wbrook_ford wbrook_ford is offline
wbrook_ford is starting off with a positive reputation.
How about one of those stick-on oil heaters? If it's that cold you should also have the block heater plugged in.
If the clutch isn't releasing, sounds like pressure plate or throw out bearing issues...
Clutch sticking, not engaging txdadof4 1987 - 1996 F150 & Larger F-Series Trucks 2 08-01-2015 02:23 PM
Squeaky sticky clutch pedal mcguire87 1987 - 1996 F150 & Larger F-Series Trucks 6 10-21-2013 11:00 PM
Transmission Temp guage install chunt 1994.5 - 1997 7.3L Power Stroke Diesel 2 09-20-2013 10:23 AM
Clutch Questions ... HouseFullofFords 1987 - 1996 F150 & Larger F-Series Trucks 2 09-15-2013 01:26 AM
Noise from my clutch when disengaged (clutch pedal to floor) olezy 1987 - 1996 F150 & Larger F-Series Trucks 6 10-14-2010 02:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
