Trans Overdrive Shift Issues - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-09-2013, 11:54 PM
Camalot Camalot is offline
Camalot is starting off with a positive reputation.
Ok, I have searched everywhere and cant find the answer to my issue. I have a 2001 Expo 4.6l 4r70w trans. It shifts fine in every gear. However, when in overdrive it constantly wants to down shift. It only does this when the trans has warmed up. When driving at about 50 mph it will all of a sudden start fluctuating from 2000 to 1200 rpm in and out of shift modes. It never slips but just kicks in and out of the two gears like it cant decide what gear it wants to be in. If I turn off the overdrive it will hold a constant 2000 rpm at 50 mph and shift through all the gears fine. Also my 4x4 light is flashing but Im sure that is a sensor issue since all my 4x4 functions work fine. Im hoping an easy fix but would like some guidance before I take it to the dealership Friday and have a scan done. Side note: I took it to auto zone to have it scanned but only came up with an O2 sensor malfunction. That would explain the check engine light that has been on since I bought it. Thank you.
Old 12-10-2013, 11:51 AM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
Quote:
As we have seen time after time, an engine misfire can sometimes be interpreted as a tranny issue.
If the O2 sensor detects an issue from too lean/rich, to measuring Cat effectiveness, a rough running engine will, at times, shift the tranny down to compensate.
At 50, it sounds like your caught between gears and with an engine stumble, it just might be searching.
Get the actual PO code and we might be able to help further.
Transmission Troubles.... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 42 11-24-2016 03:08 AM
New Rebuilt E4OD, Has Overdrive cold, No Overdrive After Warm Transam461 1987 - 1996 F150 & Larger F-Series Trucks 7 09-10-2016 01:58 PM
4r100 won't shift into 4th Slash19 1999 - 2003 7.3L Power Stroke Diesel 2 06-04-2016 09:21 AM
Transmission issues after rebuild HMS 1999 to 2016 Super Duty 12 03-02-2014 03:41 AM
Transmission occasionally shifting strangely... seebeexee 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-09-2013 10:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
