Charcoal Canister
Charcoal Canister
Hello and good morning to all!
I have a 87 F150 5.0L E4OD XLT Lariat 2WD Standard Cab.
There is an approximately 1" square hole in the Charcoal Canister mounted next to the battery with 2 rubber hoses; 1 in and 1 out I assume.
What effect will this have on my engine?
The Air Pump is coming off along with all of the plumbing associated with it but not until I finish my current modification.
That is unless I should replace the Charcoal Canister immediately.
What do you think?
Many Thanks!
Boon
What do you think?
Many Thanks!
Boon
Hello to all and greetings!
I finally made it to the boneyard; 40 degrees and sunny!!!
It took me about 5 minutes to find a EVAP Canister; 5 more to pull it and $10 to buy it.
Sweet Jesus, O'Reilly wanted $115 for it!
Case closed
Thanks for the help guys.
Take care and Godspeed!
Boon
P.S. Rich if you see this reply I sent the information regarding my nephew and all of that technical stuff so I am hopeful that he receives it soon. Thank you for the very valuable information; even if I do not have a clue what you are talking about! Ha Ha
Case closed
Boon
