What's the widest tires I can use? - Ford Truck Enthusiasts Forums
Old 06-24-2003, 12:41 PM
f150-az's Avatar
f150-az f150-az is offline
f150-az is starting off with a positive reputation.
I've heard lots of different things about the maximum tire width I can put on my 7 inch rims but I just wanted to confirm it for sure on the boards. I don't really want to get new rims just because they are pretty cool as it is. So on that, how wide can I go (in millimeters) on my 16x7 rims. Thanks guys.
Old 06-24-2003, 04:05 PM
CPerry's Avatar
CPerry CPerry is offline
CPerry is starting off with a positive reputation.
265/75 16's are the biggest tire rated for 16x7 rims. Of course you can put bigger tires on these rims but it is not recommended for safety reasons. Also tread wear will be less (will wear in the middle of tire). I considered putting larger tires on my stock rims. I have 265/75 16 tires which were on the truck when I bought it last month. They have less than a thousand miles on them so I bought 16x8 alloys and put the 265's back on. They fill up the wheel wells better now and will be on my truck until the warranty expires in 16 months when I will lift the truck and put on bigger tires.
Old 06-24-2003, 06:12 PM
JeremyH JeremyH is offline
JeremyH is gaining momentum as a positive member of FTE.JeremyH is gaining momentum as a positive member of FTE.
I wouldnt go any wider than an 11.5" wide tire for wheeling. If you deflate them at all offroad then you run the risk of blowing a bead.
Old 07-06-2003, 06:54 PM
valleyflyer valleyflyer is offline
valleyflyer is starting off with a positive reputation.
I installed the Michelin Cross Terrain 275/70/16 and they look good and ride good, and still wearing well after almost 17,000 miles.
Old 07-06-2003, 11:03 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
265 is the widest you should go for that rim. There are some who have gone 285, but it really isn't recommended.
Old 07-17-2003, 04:43 PM
alan97F-150 alan97F-150 is offline
alan97F-150 is starting off with a positive reputation.
If you've got 4x4, don't be afraid of 285/75-16's, but anything bigger has never balanced right in my experience.
Tire backspace question markeyd 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-23-2016 11:30 AM
Tire width to rim size theory... apachetech 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-06-2015 07:50 PM
Mud tires and Rim size HELP. Gear619 1987 - 1996 F150 & Larger F-Series Trucks 2 11-17-2014 11:44 AM
Rim size 2003 f150 2003 5.4l General Automotive Discussion 1 06-11-2014 01:40 AM
Opinion needed on rims & tires - FAST billygoat Excursion - King of SUVs 10 01-25-2007 08:46 AM
Tags
1999, 2002, 2003, biggest, expedition, f150, ford, lightning, put, rim, safely, tire, whats, wheel, widest
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
