97 F-150 Steering Knuckle replacement
I was able to pick one up used at a local place, they gave me a entire assembly that included the hub. The hub they gave me has the Anti-lock sensor in it, the truck I am putting this in doesn't have anti lock..can I just put it in or do I need to take the hub/lug assembly out of the new one and swap parts?
Thanks, I ended up cutting the wires off the sensor and leaving the sensor in, I figured this would be the best way to make sure no water or debris would get in the bearings.
What is the torque setting for the large center spindle nut? It appears I do not have it tight enough and the front part of the pad retainer is just rubbing the rotor. Really that is the only thing I could think off.
The swap was much easier then I had expected, I just unloaded the torque arm and reset it back to the exact amount of turns I took off.
Thanks for all the help
Originally posted by Racerguy
The spec for the axle nut is 188-254 lb.ft.
Not really sure what you mean by the front part of the pad retainer.
Thanks for the TQ setting
crobotti
1999 to 2016 Super Duty
04-09-2014 10:35 AM
