Monte's 04 Build Thread
#1669
#1671
#1672
#1673
I apologize guys ive been working on the truck just have not taken pictures because i keep getting pulled away and going back so i pic up where i left off and it just escapes my mind lol.
I will post pics tonight but what i got done this weekend was i removed the fuel pump/ injection lines off the cummins and started to disassemble to the point of where i need to clean and paint it then i am going to rebuilt the injection pump as well as the vac and power steering pumps since they are very modular.
I also got the bed supports completely off minus the front one and i have cut the new square stock to length. I just need to drill teh holes in the supports now and then the floor however i cannot get all the way through with my drill so i am going to use the drill press my grandfather has to finish and then center punch and drill the bed floor out . I got the monstaliner delivered this morning i am going to POR tonight and monstaliner the bed tomorrow. Then i just have to get some friends to help me put the bed back on this weekend!
I am anticipating a small problem with the rear most support that had the spacers. I checked the measurement and realized that the Ex tank sits above the frame where the spare tire cross brace did't. I may have to pull that brace out after the bed is on if it sits on the ex tank and cut a section out to clear the tank but that will be easy after the bed is on.
#1674
Some pictures of my progress, i stood the bed up last night in order to keep the paint from running down the sides and instead to the front. I also started to strip the cummins down for paint on the drivers side. I got the injection lines PS/Vac pumps removed and now i just need to pull the injection pump and clean the block then paint and do mods!
#1675
#1676
#1677
I have that thing is absolutely beautiful! I am simply going for black and Gray though to match the truck but dont worry I will make it look pretty. Unfortunately i dont have the time or space to go as in depth as that but I'm doing all black with some gunmetal gray accents.
I hope it looks as nice as the rest of the truck.
#1678
Oven cleaner omg that's genius! I have degreased the passenger side of the block 5 times and there is still oil and grease all over it, i will have to get some when i get home today and coat it while i paint the bed! Maybe I'll be painting the bloack this weekend if it works well enough lol.
