56 heater motor upgrade?
Thanks Jack,I think this is what I am looking for.The original works but it sure doesn't blow very hard.Even with the Fresh air set up.
Just looked up the price locally.
VDO® - Blower Motor
Part # PM350
Line: VDO
Online:
Available
Store:
Usually Avail. 24 Hrs
Other Stores
<input id="qty" name="quantity" maxlength="3" value="1" size="2" type="text">
for this item only
Add to Printable List $27.99 Each
VDO® - Blower Motor
Part # PM350
Line: VDO
Online:
Available
Store:
Other Stores
for this item only
This is what I used, looks like Amazon offers it now as well. This was a perfect fit for my 55 F100 stock fresh air heater. Works great and somewhat quiet. Just make sure you get the right rotation motor.
Red Dot Single Shaft Motors 73R0602 : Blower Motors Wheels and Fans
I am in the process of restoring the heater in my 56 f350. When first disassembled the motor did not work, I priced a new one at LMC (local company for me, right on my way home from work) think it was around $120, ouch! The 6v earlier ones are half that, WTH? Anyway messing around the shop one day and took my drill and used it to spin the shaft of the motor after squirting a little Gibbs penitrating lube down the shaft. Nothing to lose, right? Spun it for maybe 40 seconds, tested it on the battery and it runs like a champ. Just needed a little polishing up inside.
