3v 5.4 intake flow limitations - Ford Truck Enthusiasts Forums
Old 12-08-2013, 04:00 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
I'm curious how much a stock intake can flow. I have been stockpiling info for a rebuild I want to do in the next year or so. O would like to do a slight compression bump with a .030-.040 over bore to bump power some. I would also like to port the heads and do some valve work but if the intake can't flow the air needed it won't be worth my time. Thanks for any info
Old 12-19-2013, 10:08 PM
wbrook_ford wbrook_ford is offline
wbrook_ford is starting off with a positive reputation.
Unless you plan on putting bigger cams in at the same time, the build will show little improvement.
The manifold should be good to 400 hp. If that's not enough then a 4.6 3V aftermarket manifold with spacers could provide even more flow.
Old 12-19-2013, 11:16 PM
nojoke327's Avatar
Still on the fence about cams. I do tow and don't want my power band moving to far north.
Intake heat with a header jrotten67 Ford Inline Six, 200, 250, 4.9L / 300 7 01-02-2017 10:11 PM
240 head on 300 fljab Ford Inline Six, 200, 250, 4.9L / 300 41 03-22-2016 12:55 PM
Light power mods, head work idiguy90 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 08-01-2015 04:43 PM
5.0 upper intake questions smeans92 1987 - 1996 F150 & Larger F-Series Trucks 4 01-02-2015 07:33 PM
finished porting and polishing...whew roger dowty 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 04-24-2006 10:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
