Taller wheels? - Ford Truck Enthusiasts Forums
Taller wheels?
Old 12-08-2013, 04:38 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Taller wheels?
Is there any other wheels (taller) I can get for my 350 DRW so I can run taller tires. I am trying to save some fuel if I can. Or is there just a taller tire that would work without touching together?
Old 12-08-2013, 08:36 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I'm curious as to why you think taller tires will give you better fuel economy? Increasing the height of a vehicle typically increases the drag and causes fuel economy to go down.
Old 12-08-2013, 08:42 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
Quote:
He is thinking that with a taller tire it will drop his rpms hence changing the ratio in his truck setup.
Really you're not going to see a difference trying to go about it this way. I'm running 38s with 3:73s and at 65 my rpms are around 1600. I get a consistent 14 mpg.
Old 12-08-2013, 08:54 PM
jhand124's Avatar
jhand124 jhand124 is offline
jhand124 has a very good reputation on FTE.jhand124 has a very good reputation on FTE.jhand124 has a very good reputation on FTE.jhand124 has a very good reputation on FTE.
Not much you can do other than adjust driving style. A gear vendor unit would help but you wouldn't see the return for a decade.
Old 12-08-2013, 09:09 PM
trike1946's Avatar
I thought if I could even get 17s then the rpms would drop some. My truck is already sitting high with a work cap on it. I didn't think it would make it any worse. My cap is almost a foot higher than the cab. Probably it would save some if I cleaned it out. The back is full almost to the top of the cap. My back seat is full almost to the roof and my passenger seat is full, but I can still see out the window and see the mirror. Changing rims and tires would be easier than cleaning the truck out. I did it a few years ago and it took almost 3 days for the whole thing. How about a tuner? Would that do any good?
Old 12-08-2013, 09:18 PM
RV_Tech's Avatar
RV_Tech RV_Tech is online now
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
For mileage, driving style will do more than anything else you can do. I doubt wheels or a tuner will ever pay for themselves in terms of miles per gallon.
Old 12-09-2013, 07:48 PM
trike1946's Avatar
Being 67, I am not really in a hurry anymore. I don't pull out fast or drive fast unless I am trying to merge onto a highway. So I doubt there is much I can do to change my driving style without just staying home. Maybe I need a ranger or something like it.
Thanks for all the input.
Old 12-09-2013, 08:02 PM
JOHN2001's Avatar
With age is know how and I'm sure by now you know what you're doing. Maybe a ranger is the best bet, I use my jetta 98% of the time.
Old 12-09-2013, 08:08 PM
73ferdf250highboy 73ferdf250highboy is offline
73ferdf250highboy is gaining momentum as a positive member of FTE.
I went from a 255/85/16 to 315/75/16's on my drw with 4.10s. I'm not quite to 67, I'm 40 but I drive in the slow lane at 65-67mph. And I take off like I have an egg shell under my foot. I get anywhere from 13-20mpgs.
I rarely try to figure out my mpg's anymore. My rpms have dropped but my drag has gone up. I lifted the truck a couple of more inches when I got the wheels and tires.
I also had to add spacers betwix the rear wheels
Hope this helps
Old 12-09-2013, 08:42 PM
trike1946's Avatar
[QUOTE=73ferdf250highboy;13826036]I went from a 255/85/16 to 315/75/16's on my drw with 4.10s. I'm not quite to 67, I'm 40 but I drive in the slow lane at 65-67mph. And I take off like I have an egg shell under my foot. I get anywhere from 13-20mpgs.
Did you need spacers with the 255s?
Old 12-09-2013, 08:50 PM
i had 1/4" inch spacer with the 255's i cant say it needed them but had them anyways. i have a 2" wheeladapter spacer on there now.
New Tires What Size? superduty john 1999 to 2016 Super Duty 4 01-13-2017 06:45 PM
wheel chair lift need help please Greg2000K 1968-2013 Full Size Vans 11 09-27-2016 04:44 PM
Wheels and Tires brangus82 1999 to 2016 Super Duty 4 05-11-2016 11:28 AM
Tires for my EX looking for a taller 16" Tire maybe 255/85r16? A Rodder Excursion - King of SUVs 2 02-11-2015 08:39 PM
what ford rims will fit? sgettin 1961 - 1966 F-100 & Larger F-Series Trucks 2 09-28-2009 10:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
