Are more expensive tires worth it?
#32
The Michelin LTX A/T2 are a very nice highway tire but are all but useless when you need them for dirt roads with any kind of mud or in the snow. I have them on my truck as they are the factory tires and hate them. I am hoping to go to Hankook DynaPro AT/M's like I had on my Dodge as they were a very nice AT tire that was a real AT tire unlike the Michelin's and not overly aggressive as to be noisy on the highway. Alot of companies around here use the Hankook's on the dually company 4x4 trucks. Also the Yokohama Geolander AT/S is a very nice tire.
#33
#34
Noted.........
#35
Probably true but with a 245/75-17 that's smaller than any newer truck out there. Less popular sizes may be more readily available.
#36
Better tires are worth the money, i have ran several sets of hankook dynapro atm's, two weeks ago i put on dynapro mt's and i love them. My uncle has them on his f350 and they are great tires. No road noise and still have good tread at 55k miles. You may also check on some yokohama geolander ats, they are a great tire as well.
#37
#38
Mine is fine if I've got a tonne or so in the back of it. In two wheel drive light even with the limited slip it would get stuck on wet grass. Thats with six new rugged trail BFGs. With one of these bigger trucks the front end weighs so much more than the rear unless you add weight to even it out it takes a lot of traction to push the front wheels.
You could always just turn the dial to four by then you're gonna go somewhere.
#39
I would steer more towards an aggressive highway tire with a 6 wheeled truck. I have had good luck with the stock BF rugged trails on my super duty and I ran michelins on the company dually trucks I maintain. There are more than a few lifted F350/F450 duallys running the streets of Ocean City, MD with spacers between the wheels to keep the tires from rubbing.
#40
Here is 2 places to look at chain laws.
Tire Chains | AAA/CAA Digest of Motor Laws
http://www.witruck.org/state_chain_laws.pdf
#41
what you need to compare is the cost of the tire related to the miles you will get out of them. Sometimes a cheaper tire will wear better then some expensive tires, thus your cost per mile will be less. The only bad thing is there is some trial and error with this method since you will have to try a few different tires to see what wears best, unless you know people who run the tires you are looking at with a truck that is almost identical.
#42
http://m.sears.com/index-g.html#/pro...0070921x00003j
Check these Michelin XDS2 tires out.
Great traction on and off road.
Great in snow and ice.
I might add that I've seen 110k on these tires with a truck that weighs 16k lbs.
#43
Yea I definitely need a highway friendly tire.
So my thougts are the only property I'm driving on is mine, my friends, and the local dumps. All will provide a good surface not needing some mud tire to get me out. Remember I'm dragging a trailer weighing between 10,000-14,000lbs. You don't take that weight onto a surface that you'd need a super aggressive tire. I've been driving in the snow with worn rugged trails so a super aggressive tire isn't necessary. That's what 4 wheel drive is for. Probably not getting anything until spring anyways.
#44
#45
