Killing me - any help appreciated! - Ford Truck Enthusiasts Forums
Old 12-08-2013, 03:41 PM
Nick Browning Nick Browning is offline
Nick Browning is starting off with a positive reputation.
Angry Killing me - any help appreciated!
Hi there - first post.
2007 Ford Expedition 5.4L 3V with 92,000 miles on it. Ran like a champ until last night, while on freeway, in cruise, the engine bogs as if it had run out of gas (tank is over 3/4 full), then snaps back, then does it again, I pull over, engine dies. Will sometimes start from then, and will idle fitfully, then die. Sometimes will start and allow rev's to 3000 in park, but any attempt to drive vehicle results in stall.
OBD-II tester shows NO codes.
Fuel pressure tested at Schrader valve shows 60-70 psi regardless of revs (when it decides to run). Holds pressure with no problems.
I replaced the TPS (common things being common) with no change in behavior. Throttle body had very limited deposits and the throttle plate moved through its rotation without binding.
I looked for the FPDM, but could not find it in the left rear area, and all indications are that it is in with the fuel pump.
It feels like there is limited or intermittent fuel flow, but that seems highly unlikely given the adequate fuel pressure.
I could also be convinced there was a problem with the electronic throttle control, but it seems like that would throw a code. I feel a little foolish for replacing the TPS without getting a code, but it seemed easy.
Any ideas would be greatly appreciated.
Old 12-09-2013, 04:13 PM
Fixed and caught by the oldest trick in the book - empty fuel tank. Fuel sending unit malfunctioned I didn't realize. Fuel pressure was good, but flow was not.
Old 12-09-2013, 04:33 PM
offroadnt's Avatar
offroadnt offroadnt is offline
offroadnt is starting off with a positive reputation.
Derned sensor eh? I just got a 2010 F250, it has a bad sender too. I usually reset one of the trip meters at each fuelup and use that as a backup fuel gauge, I know this truck will travel at least 600km on a tank so I'll fuel up anytime before then.
Old 12-26-2013, 12:31 AM
Mat523 Mat523 is offline
Mat523 is starting off with a positive reputation.
What...I misread this thread. I thought you needed assistance in a Dr kavorkian kind of way. Just kidding of course. Merry Christmas
Old 12-26-2013, 07:02 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Well, that's a heckuva Christmas greeting huh?
Old 12-27-2013, 07:52 PM
My apologizes, I am used to sick humor.....It was just to tempting to resist.
Old 12-28-2013, 07:48 AM
JWA's Avatar
JWA JWA is offline
I think most of us took it in humor--I did so no worries!
1996 F150 seems to not want to run or accelerate in closed loop robster1213 Ford Inline Six, 200, 250, 4.9L / 300 9 09-29-2015 11:08 PM
2004 Ford Explorer fuel/acceleration issues mhofmann86 Explorer, Sport Trac, Mountaineer & Aviator 2 09-22-2015 04:45 AM
Runs rough cold,no smoke,"sticking" throttle wackercattle 6.0L Power Stroke Diesel 8 02-23-2015 11:00 PM
2004 2.3 Ranger starting issues MPetrosino 4 Cylinder Engines 0 01-21-2015 08:00 PM
Vapor lock in an EFI engine? iwals 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 10-18-2014 11:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
