Y block info ....
Old 12-08-2013, 01:17 PM
Rat Rod's Avatar
Rat Rod
Rat Rod is offline
Y block info ....
I found a 54 239 and was wondering of any of the parts off that motor would or will fit on my 272 ? Thanks for any help or info
Old 12-08-2013, 06:20 PM
pintoplumber's Avatar
pintoplumber
pintoplumber is offline
Not much, the bolts would fit. The water pump is smaller, only fits its own timing cover. Fuel pump is different, the arm is straight. The heads would bolt up, but the water passages don't line up. Distributor is different, has a tang drive. Oil pump is different because of the tang drive. Rocker arms and shafts will fit. Oil pan fits car to car, truck to truck. Intake would be slightly smaller ports, probably could get it to seal.
Old 12-08-2013, 06:29 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Gerotor oil pump may be rebuildable with a hex drive kit (Melling K-51?). Starter is likely a keeper.
Hey, on a Rat Rod, anything fits.
Old 12-08-2013, 06:31 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
There are two different 239 Y-blocks. and there are parts from both that interchange with other Y's. Here are two threads that will help with what works.
239 - 272 - 292 ford [Archive] - THE H.A.M.B.
Identifying Ford Y-Block Parts (Part 1) Precision Engine
Old 12-08-2013, 07:38 PM
Rat Rod's Avatar
Rat Rod
Rat Rod is offline
Thinks for the info I didn't think it was much that would work off of it it was in the truck when I bought it but is locked up I only have a $100.00 in the truck and I found a 272 and another 3speed so I jst bought it I goin to build a rat rod out of it I was told the timing cover and water pump would work so I'm goin to swap it out jst so I can keep the old cool looking fan .....
Old 12-08-2013, 07:59 PM
pintoplumber
You'll want to use the 239 fuel pump with the 239 timing cover too.
Old 12-08-2013, 08:04 PM
Rat Rod's Avatar
Rat Rod
Rat Rod is offline
So the 239 fuel pump will work on the 272 if the timing cover is changed out if so I will use it if it works I will have to test it I was thinking of goin with a elec. pump and a regulator what you think is best ?
Old 12-09-2013, 05:27 AM
pintoplumber
You might want to rethink about using the 239 stuff. Ford went to a larger water pump on the larger engines for a reason. I think a mechanical fuel pump would be fine, you wouldn't have to add the extra switches to kill the electric fuel pump in the event of an accident.
Old 12-09-2013, 05:46 AM
Rat Rod's Avatar
Rat Rod
Rat Rod is offline
Ok thanks I never really thought about that but it does make since and I really didn't want to swap them parts out anyways lol so now I'm ready to drop the motor in the truck when it gets warm enuf outside !! Thanks
Old 12-09-2013, 07:17 AM
The Horvaths
I will be the first, but, probably not the last to suggest that the term "rat rod" gets the goat of many members of this otherwise warm and welcoming forum. The general consensus seems to be that many a restoreable truck is converted into a poorly "engineered" and all too often unsafe vehicle. So, have fun but please be safe.
I'm just sayin'
Old 12-09-2013, 08:08 AM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
I was going to say that as hard as it is to find the early water pump I'd rather upgrade to the newer style WP
Old 12-09-2013, 09:16 AM
Rat Rod's Avatar
Rat Rod
Rat Rod is offline
I guess I mite be using the term rat rod wrong !! My trucks is goin to be safe my kids will be riding in it is not goin to be a chop / hack job in goin to look jst as its suppose to jst goin to leave the dints and paint the way it is I guess you could say it goin to be a poor mans restoration I don't have the funds to bring it back to the showroom shine it once had I got the truck off a guy who's wife was making him get it out the yard for a awesome deal all original bumper to bumper with title for a 100.00 so I'm goin to fix it the cheapest safy way passable !!
Old 12-09-2013, 12:52 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,610 Likes on 1,454 Posts
Well, now you got to show us pictures! It sounds like you are just keeping the patina, as they say in some circles. Patina is just a fancy word for rust and small dents and scratches!
Old 12-09-2013, 01:13 PM
Rat Rod's Avatar
Rat Rod
Rat Rod is offline
Lol that is exactly what I got planed to do I that they look awesome like that too . I will post pics when I can get some better ones I got a few on my phone but not sure how to post them on here from a iPhone lol
Old 12-09-2013, 04:48 PM
greenmachine55's Avatar
greenmachine55
greenmachine55 is offline
Rat Rod...just did all of this. Everyone is right who has answered back. Also remember about the 3 bolt carb mount on the intake manifold. The later Y blocks, 292 & 312's (I think the 272's also) had a 4 bolt carb to the manifold; plus, they had no draft tube because the pcv valve was introduced in those years of the higher cubic inch Y blocks. Any questions, just email.
Quick Reply: Y block info ....
