fuel filter light - Ford Truck Enthusiasts Forums
fuel filter light
Old 12-08-2013, 10:19 AM
rjrandy96 rjrandy96 is offline
rjrandy96 is starting off with a positive reputation.
fuel filter light
I have 93 f350 with 7.3l idi non turbo. i run in the winter time 50/50 wmo and #2 diesel. but recently its been getting extremly cold so prior to mixing the diesel and oil iv been putting an anti gel additive in the diesel. and sense i started doing that my fuel filter light comes on if i hit the gas hard. I heared the issue is the additive and oil makes clumps and i should just not use it because the oil will make it thick but will stop it from gelling up. Is any of this true?
Old 03-06-2014, 11:36 PM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
your CFFF (cold fuel flow factor) of your fuel filter is to low...or your filter needs changed, and or your fuel heater in the top of filter head is not working. or your lift pump is weak. cuz your ip is pulling on the filter head, and triggering the light. the Ip has a transfer pump in it that, can pull on the fuel, the switch in the filter head is like 1lb of neg pressure or a vacume. to trigger, the light.
Old 03-17-2014, 04:40 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
When I'm running a fuel mix too thick for the temperature, I can actually feel when the engine starts starving for fuel. Mine doesn't have the filter light so it's all by feel.
Many guys who burn oil mix it with a little bit of gasoline to thin it out and help it ignite easier. About 10% gasoline in your oil is said to be the best mix, then take that mix and mix it into your diesel like you've been doing with just oil.
06 F250 running rough TacoSplitter 6.0L Power Stroke Diesel 1 01-04-2016 09:53 AM
f350 diesel water problem Wbratberg 1999 to 2016 Super Duty 15 10-07-2014 08:17 PM
2-stroke oil vs. Fuel additive Fabbed5.0 6.0L Power Stroke Diesel 7 10-04-2013 12:11 PM
Fuel Additive midapo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 39 05-07-2013 10:09 PM
how to make a high mileage 6.9l diesel last longer waystro Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 10-10-2012 09:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
