7.3 wont glow..
Old 12-08-2013, 08:07 AM
Webasto 9.1KW's Avatar
Webasto 9.1KW
Webasto 9.1KW is offline
7.3 wont glow..
I just changed the GPR when I thought that was broken but it didn't fix the problem.
When I turn the key it wont engage the glow plugs. (you can see when it does as the volt gauge drops to almost nothing...)
There are two small cables aswell from the GPR... What are those?
Any ideas?
Old 12-08-2013, 08:19 AM
Hussler's Avatar
Hussler
Hussler is offline
What GPR did you purchase?
One small wire goes to fuse #22 so has power with key on.
Other small wire is pulled to ground by the PCM to activate the relay.
Old 12-08-2013, 08:31 AM
Webasto 9.1KW
An expensive one. Thanks, gonna check those out.
Old 12-08-2013, 11:59 AM
madpogue's Avatar
madpogue
madpogue is offline
"Expensive" doesn't mean "good". What BRAND did you get?
Have you TESTED the circuit? Resistance of the glow plugs, continuity of the wiring, etc?
Old 12-08-2013, 12:04 PM
Webasto 9.1KW
I know and I saw now that I kind of lied there... It wasn't that expensive.
Called "Diesel Rx" but it should just work at least right?
Old 12-08-2013, 01:39 PM
Krisx125's Avatar
Krisx125
Krisx125 is offline
Replace with a plow solenoid...and wire a push button on dash...done! Plus they have a loud click...so when they crap out you know it!
Old 12-08-2013, 05:26 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Do your diagnostics then get back to us. No need to butcher anything to make thing work like they were designed to
Old 12-08-2013, 05:39 PM
Action4478's Avatar
Action4478
Action4478 is offline
THe EOT sensor is first in line .. Make sure that is working
Old 12-08-2013, 06:25 PM
Webasto 9.1KW
What is that?
edit: ah Engine Oil Temperature...
I'll check it. If I understand it right that would tell the GPR that the engine is cold all the time if that was broke is that right? In that case the glow plugs should be on rather than off all the time...
Old 12-08-2013, 08:43 PM
madpogue's Avatar
madpogue
madpogue is offline
It's not that simple. Everything goes through the PCM. The PCM reads the EOT, and sets the run time for the GPR accordingly. The MAX GPR run time is two minutes. But on _some_ trucks, if the EOT reports the engine is fully warmed up, the PCM doesn't energize the GPR at all.
But as said, start with the simple electrical tests on the relay and its circuitry.
GJWallace
04-08-2016 08:13 PM
SteveH-CO
1999 to 2016 Super Duty
03-22-2010 10:43 AM
pumper
10-29-2009 08:36 PM
loudmusic88
10-10-2009 10:06 PM
therifleman556
07-31-2009 04:09 PM
Quick Reply: 7.3 wont glow..
