Borderbum's Diesel "Bandit"
#31
#32
#34
The later Ford diesels had them also. In fact, I just replaced a pump and boost unit on a '99 1 ton Ford dually. The hydraboost eliminated the need for a vacuum pump which Jeff's engine likely has, since it had a normal booster on it. The vacuum pump should be on top, next to the alternator.
#36
#37
Don't plan on getting rid of them, since I'm starting major surgery with Bandit, might as well start getting parts. I know ill have to put a body lift on there so might as well start with new body mounts, new bolts and the new bl.
#38
If I may ask how are you positive that you need a body lift yet? Or it that the word on the web, just curious, that's all.
The only different in the poly versus rubber in reality is the cost and color options. Red is the common color used by Energy Suspension.
energysuspension.com | Welcome
Race trac trim goes on everything easy with new mount hdwr, LMC has it and all the other repro bushiness.
If you do not have the holes in the first place in the bed door or fender, its a measure 5X's times and drill once deal.
#39
#40
#42
After I get off in the morning, I will have some days off, I cant wait!! Finally be able to figure this 79 out.
Besides new oil and oiling the cylinders, what else should I look for getting this 400 in the truck ready to start? I saw it earlier on the BS thread, but it is lost in the many pages now! lol
I will make my lists and not sure if I will head north this week or not, Alan, let me know if your interested in this week or next tuesday or wednesday morning.
#43
#44
1. Open each cab door there is one on each side between the upper and lower hinges (that's 2)
2. Underside each front fender on the back side there is one right on the bottom edge of the fender (that makes 4)
3. One on each side of the radiator, way down on the side. These are the ones that give most folks trouble due to their rusted condition. And if you can not get them to wrench loose, is sawzall time. If you are trying to save the body mount, cut between the bottom of the radiator core support and the top of the frame. ( that's 6)
NOT counting the 4 for the hood. 2 on each side that hold the hood to the hinges.
Where the inner fenderwell bolts to the cab firewall there are 3 on each side just aft of where the hinges mount. (that 6 more for a total of 12) Did I say 14...so I can't count. lol
And I do not count the rubber strap going from the dvrs side inner fenderwell that is sometimes still there, its below the power brake booster/master cylinder. I have never seen one on the passenger side inner fenderwell.
0.02 concentrate the $$ on the motor swap and what ever it takes first, then figure out all the rest. The body lift being 1st, in case its needed, then the suspension, body panels ect....
#45
