Dana 70 question
Dana 70 question
Guys can a Dana 70 rear axle from a 1965 to 1972 F350 run a 3.54 ring and pinion with a carrier change? I have been told 4.10 is the tallest gear that can be run in these year model axles. Could someone also tell me if braking and / or stoping a load would be significantly improved if replacing a Dana 60 under a 1966 F250. Any advice / information appreciated. Thanks!
1961/65: 4.86 - 5.23 - 5.87. 1966: add 4.10 & 4.56. 1967/79: add 3.73, subtract 5.87.
3.73 & 4.10 use a different case than the other ratios.
Or online for $205 plus shipping:
Motive Gear DANA 70 Gears
OP's 1965 F350 Dana 70's ring gear & companion flange have 10 splines, u-joint has 1310 sized cups.
1967 and later, the companion flange has 29 splines, but there are 3 different types as there are 3 different sizes of u-joint cups: 1310's, 1330's or 1350's.
Most likely the R&P that the OP buys, the ring gear will have 29 splines, so he'll have to change the companion flange.
cooperstown24
05-21-2019 09:27 PM
pm042070
11-06-2014 09:44 PM
ian's truck
12-16-2012 04:44 PM
