Norfolknova's 66 F100 Build
Just curious, what type of tank are you putting in yours? Are you mounting a tank behind the axle. I need to take some measurements on my 92 F250 and see just how wide the tank is and see if I can make one of them fit between the frame rails.
If it is not too cold tomorrow I am going to try to get the CV front cross member mounted. I am just not a big an of freezing while I work on cars.
Matt
I did manage to brave the cold, well o.k., it really was not too bad out. I mounted the Crown Vic front subframe and it is back n all fours as a roller. I still need to pick up some plate to box the front frame where the subframe is mounted. Make the mounts for the lower control arm radius arms, I might be able to re-purpose the 66 radius arm mounts. Then comes mounting the Mark VIII rear suspension in a couple of weeks.
Matt
Matt
Matt,
That's a ton of work looking at the new front end and I don't wnat to be the one to .....ss on your parade but I noticed mechanic58's comment about track. Granted the 66 had a bit of a stagger from front to rear to begin with but from the picture showing the installed crown vic suspension.......your wheels look like they're tracking about a foot outside the rears. I'm no expert but it looks like the spindles combined with the control arms are what seems to be messing things up. Hope it's only a visual trick! It kills me to see anyone invest that kinda effort and have the work be for nothing.
Hope it works to your advantage.
Originally Posted by mechanic58
Ok - here's the measurements:
1962 F100 straight front axle track width, measured at the CL of the tread on each tire and averaged taking into consideration the tow, front and rear - 61 5/8".
2004 Crown Victoria P71 Police Interceptor, measured the same as above - 63 1/4".
Now, these numbers are deceiving due to the different offsets of the wheels. My F100 has some 70s model ford truck steelies on it. I believe they're 6" wide with a 0 offset. The CV on the other hand has a very deep backspace on the wheel. I believe they're 8" wide with at least a 5 1/2" backsapce. So with 0 offset wheels on the CV front end, the track width would then be 66 1/4" and possible more. I'm not positive on the backspace on those wheels.
So, this means that the CV/GM front ends are roughly 5" wider than the stock F series axle. Now I don't know how the straight axles compare to the twin i-beams, but I'd guess they are probably pretty close.
Matt,
I think part of the major difference is visual, but I am not keeping the stock solid axle rear axle. The truck is getting the Lincoln Mark VIII IRS. The Mark VIII has a similar track width to the Crown Vic. Most of my friends are Mustang people so after I get the body back on I will fit a couple of different sets and see what fits under the fenders, or I may have to order a set of wheels with deeper offsets.
Another reason I think it looks awkward and so much wider in the front is the donut spares I have on there. I picked those up cheap at pick and pull so I would not have to worry about damaging a good set of wheels in the build process.
Next weekend I will try to throw a set of Mustang wheels on the front, I am also going to set the engine on the mounts so I can fab up a proper front cross member. I just used a piece of 2 inch angle iron to keep the frame from spreading when I removed the factory cross member.
Plus the design of the fenders lends themselves to be modified a little (While it won't be easy) to widen the flares to fit a little wider track.
I will be sure to post up what size wheels I use when I get to that point
Thanks
Matt
Thanks again
matt
#29
Up next is making a cross member to go in front of the subframe, boxing the frame where the sub frame is mounted, and I need to make a piece the will go over where the sub frame nuts are and the upper shock tower brace will bolt down to. After I am done with the front end i will move to the rear. That will take me a couple of days working on it just to get all of the brackets off of the frame. Then i can mount the Mark VIII rear axle
Once all of the suspension is done I am going to soda blast the frame and paint it with POR 15
Matt
Matt
#30
