Finally started my York Air today - Ford Truck Enthusiasts Forums
Old 12-07-2013, 04:23 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Thanks to Todd for reminding me. I had some time today, I was planning on checking out the rear end I bought for my dually conversion, but the shop is kinda full, too cold to move my poor truck outside, so I decided to work on the york.
I used a piece of angle, 3/8 thick x 4" x 6 1/2" x 10" long. I had it laying in the scrap pile, and it was just perfect to cut up. I wasn't quite wide enough, so I put the piece of angle on top. It's 3/8 think too, and hangs over to the rear of the truck, two mounting bolts through it to the pump, and one to the alternator bracket. Center cut out for access to the fill plug. The angle did two things, it made the piece wider for the back bolt holes, and reinforced the top. It's quite strong. The mounting holes are all elongated, so you can pry the york over and get the belt tight, then tighten the 4 bolts on top. It's a 32 inch belt. It's sure nice of the bracket on the motor to have 2 threaded holes on the front below the alternator, they came in handy.
The other part I got done today is moved the IC pipe on that side. I had ordered a 3 inch somewhat of a "J" bend a long time ago to use. It was real easy, I cut that piece 3 times, turned a piece or two to line things up, tacked it, removed and welded up. Painted and installed. I welded a lip on the end so the boot doesn't blow off on high boost, kind of like Jake's are, but a little more crude. It will work though.
Tomorrow i may see about getting the tanks mounted. Then its just a matter of running lines and wires and hooking it up.
Here's a few pictures.
Old 12-07-2013, 04:39 PM
madMatador78's Avatar
madMatador78 madMatador78 is online now
madMatador78 is gaining momentum as a positive member of FTE.
Sweet Darin! I'm assuming this so you can have an on board air compressor?
Old 12-07-2013, 04:43 PM
Thanks Thomas, you are right.
Old 12-07-2013, 06:17 PM
Cool Beans! That will be very nice to have I'm sure. And even nicer when its all done!
Old 12-07-2013, 06:48 PM
Yes, it will be a nice addition to the truck for sure! I'm not real good at getting this all figured out how to wire and plumb, but I've got a friend coming over to the shop tomorrow who is good at this stuff and can guide me a little bit. I also pm'd TJ who has this on his truck, but he's not on here much anymore so we'll see.
Old 12-07-2013, 09:08 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Looks good Darin!! I gotta get me one of those!
Old 12-07-2013, 09:20 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
What PSI and CFM is that good for?
Old 12-07-2013, 09:55 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
How is the compressor pulley attached to the alt pulley.
Looks good.
Old 12-07-2013, 10:52 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Looks great Darin!
Old 12-07-2013, 11:28 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
That should come in real handy for you Darin.
Old 12-08-2013, 05:30 AM
Thanks guys. I've only been planning on doing this for 4 years...
Brad, it should be able to set it at 150psi. I'm unsure of the cfm though.
JR, it's a double pulley from kilby. It just replaces the stock pulley.
Old 12-08-2013, 07:20 AM
UNTAMND's Avatar
The York compressor is impressive.
This is from the kilby website for the compressor they sell.
4cfm at 90psi and capable of 8+
::Kilby Enterprises::
I was hoping the pulley was an add on thing because I have an overdrive alt pulley, but they offer a 1.9" diam to help out. Now I'm interested for sure on doing this.
It's great inspiration.
Old 12-08-2013, 07:36 AM
So what will the on board air do? Not too much cfm to run tools
Air a tire? or air bags?
Old 12-08-2013, 08:09 AM
tshrager's Avatar
tshrager tshrager is online now
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Very cool Darin!
Old 12-08-2013, 09:07 AM
UNTAMND's Avatar
4-8 cfm is better than most 110v air compressors, being that they only put out like 5-6. Granted on a truck you don't have the big air tank reserve, but on the trail or beside the road, it will do just fine. It's not like this is his big service truck for commercial use.
I have a big twin head liquid cooled compressor with a 6 rib serp belt, that puts out some air, but won't fit under the good of my psd. So I'll do this York addition soon I think.
MustangMatt's low buck F-150 project mustangmatt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 09-26-2016 09:26 PM
My 1986 Flareside restoration (picture heavy) nickmobile67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 49 12-27-2015 10:36 AM
Its been awhile, Very busy on my end PICTURES Cajunboxer 6.7L Power Stroke Diesel 12 08-14-2015 08:12 PM
On Board Air is finally done 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 46 03-29-2015 10:07 PM
My first attempt at real body work--Painted! 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 51 06-19-2013 07:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
