Gasket Intake Manifold Q on a V8 - Ford Truck Enthusiasts Forums
Old 12-07-2013, 12:37 PM
Hocus Focus Hocus Focus is offline
Hocus Focus is starting off with a positive reputation.
Replacing my intake manifold on a 02 Explorer XLT V8
Question; The AM manifold has the gaskets already in the manifold.
Should I use a sealent like RTV around all the rubber gaskets that are already in the manifold.
Thanks
Old 12-19-2013, 11:21 PM
wbrook_ford wbrook_ford is offline
wbrook_ford is starting off with a positive reputation.
No way. The integrated gasket is one of the single best inventions, if for eliminating mess alone
4.2 V6 - totally confused about getting the right intake manifold gasket jbourne84 1968-2013 Full Size Vans 3 02-21-2016 10:09 AM
Exhaust Gasket Install wollow007 1961 - 1966 F-100 & Larger F-Series Trucks 3 10-27-2015 03:15 PM
intake manifold gasket set part# Special Ed 6.0L Power Stroke Diesel 33 02-11-2012 11:45 PM
changing intake manifold gasket B Dobz 1987 - 1996 F150 & Larger F-Series Trucks 3 05-08-2011 10:09 PM
does a 351m need a valley pan gasket under the intake manifold? black water 1973 - 1979 F-100 & Larger F-Series Trucks 11 11-01-2010 11:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
