oil draining from filter housing
Hi all. have a late 04 6.0 appears to have a 03 oil filter base given the design of the turbo oil feed line.
Issue is after 10-15 minutes the oil filter housing drains out. I have the updated stand pipe and a new antidrain back valve, MC filter and cap. Do the seals and or springs wear out in the drain/fill valves in the base where the oil filter sits?
There are two bypass valves on that filter base too. IIRC (and someone correct me if I am wrong) There is a oil cooler bypass valve that opens when the oil pressure in the filter housing is 20 psi less than the oil cooler inlet. There is s oil filter bypass valve that bypasses the oil filter if the pressure differential exceeds 25 psi. Then there is the oil filter housing drain valve that drains the reservoir when the cap is removed.
it takes about 4 seconds of cranking before starting, and 4 seconds before pressure registers on the gauge. After oil pressure registers, the sound pitch of the motor changes.
It wasn't always like this, it could sit over night when I pull the filter it would be soaked and I could hear the oil draining from the housing.
I'm not sure you can get parts to replace them although you said you had replaced the anti-drain back?
After looking at that oil housing pic, wondering if the oil cooler bypass is maybe stuck open, given my delta is ,under normal driving, almost always less than 4* now.
I would agree that this is most likely the issue (or some kind of HPO leak) as compared to the oil filter housing being empty.
