buzz from around transmission and loss of power??? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-06-2013, 05:31 PM
Orpackrat Orpackrat is offline
Orpackrat is starting off with a positive reputation.
'97 F350 7.3 powerstroke, banks turbo 4x4 5-speed.
Transmsion oil good and full, it get a buzz in a sense from the transmission area that also comes with a loss of power, it comes more often now as before it barely came.
http://static.photobucket.com/player.swf?file=http://vid1278.photobucket.com/albums/y512/GreaseSolutions/20131206_142117_zps1025ef5c.mp4
You can hear it in the video, I hope its not serious, its by only work truck.
Thanks...
Old 12-06-2013, 11:18 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Are you talking about that hissing noise? That's the EBPV - exhaust back pressure valve - closing. Perfectly normal on a cold engine on a cold day. Helps the engine warm up faster. If it persists when the engine is warmed up, something else might be wrong.
Old 12-06-2013, 11:50 PM
osu711 osu711 is offline
osu711 is starting off with a positive reputation.
thats what it sounds like to me as well, EBPV
Old 12-07-2013, 03:01 PM
Quote:
It has been doing that engine warm or not and kills the trucks power.
Old 12-07-2013, 04:14 PM
Then your EOT - engine oil temp sensor - may not be working right, may not be telling the PCM that the engine is warmed up. Or the valve may be stuck part closed. A lot of guys just pull the downpipe to look in and make sure it's open, then disconnect it.
BTW, you were probably hearing it around the tranny because the shifter boot is probably torn, or the plastic bezel is cracked, or loose. A LOT of noise can come up through there if it's not snug and in good shape. If you esp. notice it getting louder and quieter as you change gears, that's the boot/bezel moving allowing more / less noise through. Check it out, may have to fab something to seal it up better, you'll be right pleased how much it quiets down the cab.
Old 12-07-2013, 04:49 PM
Hussler's Avatar
Hussler Hussler is offline
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
On 97's the EOT needs to get above 175* for the EBPV function to disable. Hard to do in winter months unless working the engine hard. I don't know what idiot came up with that value. On restart if EOT is above 135* then PCM will not cycle the EBPV so sometimes you can get the engine temp up a bit then shutdown - restart. Or, just unplug the EBPV and the PCM will ignore it.
Old 12-07-2013, 08:45 PM
I suspect the alternator is going out, it takes longer and longer for the alternator to "Wind Up* and start producing. Yesturday it was bouncing around for a bit before leveling out.
I don't run any lights or heaters till it starts producing constantly. It will "wind up" faster with a raised rpm than constant idling....
Does that sound like the alternator going out?
Can you spell out the different terms, EOT, EBPV, PCM, and such?
Does anyone have pictures of the parts, know the relative ease of access of changing the or disconnecting? Since this us my work truck (boss/company owned) I need to submit the info to him before I can get the work done and let him know the importance of it all.
Thank you.
Old 12-07-2013, 08:56 PM
Will add, yesterday, I was working without the trailer due to the road conditions so I was not towing a couple tons behind the truck so the lack of heat could have been a factor, I know going downhill I had the sound even more. I was blasting the heat to warm up myself and my gloves after being in the cold 15* + a windchill.
With the equipment I have in the bed of the truck, overall the truck tips the scales at about 5 tons.
Old 12-07-2013, 09:06 PM
Hussler's Avatar
EOT = Engine oil Temp
EBPV = Exhaust Back Pressure Valve
PCM = The computer
The colder it is the longer the GP's (glow plugs) are on and the alternator won't output much until they turn off, perfectly normal.
Old 12-09-2013, 08:38 AM
If I simply unplug the EBPV, will that harm the truck?
Will it stop the issue providing it is the EBPV clogged up or needing replacement?
Old 12-09-2013, 09:19 AM
The valve usu. doesn't clog up. It just closes when it shouldn't. If you make sure it's open all the way, then unplug it, you'll be fine.
Old 12-09-2013, 03:45 PM
And if its closed and unplugged, not good?
I'm on the road for a week right now and don't have the tools to pull it atm...
Old 12-09-2013, 03:59 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Just unplug it, it will be fine. Single wire plug, under where intake hose meets turbo
Injector, UVCH. no power/ rough idle jdneal88 1999 - 2003 7.3L Power Stroke Diesel 16 01-02-2017 01:35 AM
issues again, Lots of codes pcarr4 1999 - 2003 7.3L Power Stroke Diesel 1 12-14-2015 10:41 PM
What is this part?? Makes buzzing sound when I turn the key Resendiz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 11-08-2015 11:11 PM
solenoid buzzing but no start garretttt4 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-25-2015 12:51 AM
1989 F150 5.8L stalling Kenny2428 1987 - 1996 F150 & Larger F-Series Trucks 6 05-06-2015 07:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
