Tennessee Chapter Join Chapter Leader: harleymsn
Help in east tn
Old 12-06-2013, 01:58 PM
Murph2006's Avatar
Murph2006
Murph2006 is offline
Help in east tn
Hey guys it's been a few years since I been on here. Hope everyone is doin good. I've managed to acquire a fuel injected truck. It's a 90 f250 5.8 e4od. I've posted in the tech forums and got no replies. Hope some tn brothers can help. It will try to run but dies. It won't idle at all and to keep it running I have to pat the pedal. When I try to rev the engine it dies. I can put gas in the throttle body and it will run fine til it burns it. I've got spark, air, and fuel. Fuel pressure is 40 pounds key on engine off, 30 with engine running. Can't find any vacuum leaks. Check engine light doesn't come on at all. I'm pullin my hair out. Could this be ecm issue? Thanks.
Old 12-10-2013, 12:53 AM
tnguynaford's Avatar
tnguynaford
tnguynaford is offline
Sounds a lot like a bad vacuum leak. Could be EGR valve stuck open. I would check that. You can test it by removing it and pour some water on the inlet side. It should hold water. If it leaks water through, it will leak exhaust through giving a lean air/fuel ratio.
Old 12-10-2013, 03:37 PM
Murph2006's Avatar
Murph2006
Got it straightened out today. Turned out to be the map sensor. Thanks for your help.
Old 12-10-2013, 04:19 PM
tnguynaford
Glad you got her fixed Murph
Old 12-10-2013, 04:40 PM
Murph2006's Avatar
Murph2006
Me too man. Now I gotta fix a kinked tranny line and this ol truck will be ready to work.
samthehogman
10-15-2018 02:19 PM
anthonym92
06-02-2015 02:01 PM
h2eter
43
11-03-2012 05:19 PM
tinctorus
3.8 & 4.2L V6
05-03-2010 06:42 PM
surfnturf
07-10-2009 09:47 AM
Quick Reply: Help in east tn
