Wiring harness question - Page 2 - Ford Truck Enthusiasts Forums
Old 12-07-2013, 01:02 PM
Duey's 51 Duey's 51 is offline
Duey's 51 is starting off with a positive reputation.
Sacramento Vintage Ford has complete wiring harnesses with fabric over PVC, but not cheap.
Bill
Old 12-07-2013, 04:14 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
When rewiring a vehicle (depending on your knowledge of electrical and experience ) looking at a complete wiring kit can appear quite daunting but go slow one section,one circuit and one wire at a time and it's not to bad a job . I really enjoy wiring but that's just me .
Old 12-09-2013, 10:17 AM
Tilleyman's Avatar
Tilleyman Tilleyman is offline
Tilleyman is gaining momentum as a positive member of FTE.
Well, I'm an architect not an electrical engineer.
Old 12-09-2013, 10:24 AM
Tilleyman's Avatar
Dennis - my wife is from Coatesville and I grew up in Hockessin. We're in Lewisberry now, about halfway between York and Harrisburg.
Old 12-09-2013, 01:36 PM
dennisb56's Avatar
dennisb56 dennisb56 is offline
dennisb56 is gaining momentum as a positive member of FTE.dennisb56 is gaining momentum as a positive member of FTE.
I sent you a PM
Old 12-09-2013, 02:35 PM
FortyNiner's Avatar
FortyNiner FortyNiner is online now
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Quote:
And I'm a business major and got it done. This isn't design engineering just color matching and ruler work. Kind of like GerAnimals for those of a certain age.
DW
Old 12-09-2013, 03:03 PM
Tilleyman's Avatar
I can handle color matching!! And I'm ok with a ruler too.
Old 01-17-2014, 01:47 PM
Tilleyman's Avatar
Ok, I bought my wiring harness and at the far left it has circuit 13B-B1 which it says goes to "Pillar Lt Ckt". Is this the dome light?
Old 01-17-2014, 06:39 PM
FortyNiner's Avatar
I would say yes. The lines for the fuel sender and the dome light run up the pillar and over the side window to the back of the cab.
DW
Old 01-17-2014, 11:57 PM
Holehawgg's Avatar
Holehawgg Holehawgg is offline
Holehawgg is gaining momentum as a positive member of FTE.
Quote:
My frame and subframes are coming back from the painters tomorrow. If you get bored you could always head down here for a day or 5 and help me with mine when the time comes cause the wiring scares the crap out of me. And did you ever get that pattern for your front window. I must apologize for I completely missed your pm way back. If you do need it I can sure trace out mine and send it up to you. Sorry for the hijack. I went with the Rebel wiring kit. Its marked well for each circuit but I went with 12 volt for mine.
Remi
Old 01-18-2014, 09:40 AM
Tilleyman's Avatar
Thank you Fortyniner. Since I'm moving the gas tank to the rear I guess I'll have to do some rerouting.
Chassis Wiring Harness F-350PSD 1999 - 2003 7.3L Power Stroke Diesel 1 12-05-2014 08:52 PM
Wiring Harness Dbass1292 1961 - 1966 F-100 & Larger F-Series Trucks 3 09-14-2014 07:07 PM
86 6.9 glow plug wiring harness farmerash Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 05-11-2014 08:14 PM
IGNITION SWITCH FOR MY NEW HARNESS highguy2012 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-03-2012 12:51 AM
How to splice one wire into the two-wire clearance light harness? xbrotherx 1987 - 1996 F150 & Larger F-Series Trucks 7 01-22-2012 09:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
