help please - Page 2 - Ford Truck Enthusiasts Forums
help please
Old 12-06-2013, 09:24 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
If you are using the electric pump to help the mechanical pump it will be on the low pressure side . It cant hurt as long as the original fuel pressure regulator is in place . Un needed fuel is returned to the tank. As far as the heat problem , it is most likely the t stat . My wag is you have a different problem than the available fuel ( tank pick ups , tank selector valve valve ect) On the safety side , you can add the original inertia switch in line from the 99
Old 12-09-2013, 12:40 PM
d4klutz d4klutz is offline
d4klutz is starting off with a positive reputation.
Current update.... I discovered that the injector/ glow plug harness pigtails have gotten brittle and broken. I have ordered the replacement pigtails (4 for 71.95 shipped). They should be here Thursday. I am hoping that it will allow me to troubleshoot the fuel delivery issues better. This is possibly the source of all my issues.
97 7.3 Powerstroke Dies while Driving twice had to be towed WoodBoss 1994.5 - 1997 7.3L Power Stroke Diesel 8 10-01-2015 10:39 PM
7.3 idi died on road pat420swed Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 03-19-2015 01:00 PM
Idle problem above 80 degrees F sundvl76 1997 - 2003 F150 3 03-24-2014 03:00 PM
2004 f150 died, restarted VERY hard guessrow 2004 - 2008 F150 1 03-10-2014 08:04 PM
Fuel pressure problem 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 10 01-10-2014 10:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
