S300CG?
Old 10-12-2013, 02:01 AM
Tim Shultz's Avatar
Tim Shultz
Tim Shultz is offline
S300CG?
I have found a oil and water cooled S300CG Borg Warner. Yes, a water cooled S300. However, I cannot find ANY specs on it at all.
Its a Borg Warner S300CG part number 176488.
Also looking for info on two other Borg Warner turbos,
S200S057 pn RE515501
S2A pn RE508971
Any info or a place selling rebuild kits for any of these 3 turbos would be great!
Old 01-05-2014, 06:12 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
I did a quick search and came up with these items for you to browse through:
https://www.google.com/search?q=s300...ient=firefox-a
This link has your part number associated with it, so it might provide the info you need:
02-08 Caterpillar Military S300CG Turbo 176488
I found this for the S200S057:
https://www.google.com/search?q=S200...ient=firefox-a
And this for the S2A (RE508971):
RE508971 turbochargers, RE508971 turbo, RE508971 turbocharger, RE508971 diesel injection
I hope these help in some way.
Old 01-09-2014, 05:18 PM
turbonatorboyz's Avatar
turbonatorboyz
turbonatorboyz is offline
S2A pn RE508971
the s200S057 has a 57mm compressor wheel, and a john deere PN RE51501, same with the S2A, john deere PN 508971( the prevoius info states its for a 4.5l, so pretty tight)... the S300CG, identifies it being gated (G is gated, the previous info says it has an .80A/R turbine housing and its off a 7L, so best choice of the three) hope this helps...
MisterCMK
Garage & Workshop
10-21-2007 12:30 PM
oldcoupe42
Garage & Workshop
03-11-2005 09:12 AM
Quick Reply: S300CG?
