Engine turns but wont start
I recently bought a 2003 f350 7.3, I ordered a tuner for it and tried installing it, at one point while the ECM was still connected I did something and it sparked. Then the powertrain relay (302) started clicking really fast. It clicked in the on position. I switched it with another and it was also clicking. So since I sparked the ECM I figured I messed it up. I ordered another one and it's doing the same thing. Then I pulled fuse 45 (which was good) and put it back in. When I turned truck to on position it wouldn't click anymore, but it still won't start...anybody have an idea of what it could be? Ive ruled out the ECM, powertrain relay (302) and fuse 45, I don't know what else to check. PS not very technical with vehicles
I didn't have my batteries disconnected when I installed mine, and my truck starts every time. Jody's instructions state that the key needs to be removed from the ignition, so that's all you need to do.
I recommend contacting your tuner, they've most definitely ran into this type of problem before I'd imagine.
BigBlackF-250
10-15-2015 06:56 PM
onebigtruck
11-02-2011 10:57 AM
