1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
a/c not working
Old 12-05-2013, 06:53 PM
hotrodhippi's Avatar
hotrodhippi
hotrodhippi is offline
a/c not working
hey everyone I have a problem with my 2000 F250 4x4. The a/c started to go out. At first it would work for about 30min. than slowly go to warm. After a couple of weeks it quit working all together. I have checked the low pressure sensor and that has power but no power to the a/c clutch. System is good on refrigerant and all fuses and relays are good. a/c switch on the dash is working. Does anyone have any suggestions. Thanks for the help.
Old 12-05-2013, 06:55 PM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Hi hotrodhippi and welcome to FTE!
You might want to start with this:
Old 12-05-2013, 07:09 PM
hotrodhippi
Thanks redford, I'll give this a try but I noticed that in the video he engages the clutch. I have no power to the clutch so it will not engage.
Old 12-05-2013, 07:14 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
What was the outside temperature when you were conducting your tests?
Old 12-05-2013, 07:21 PM
hotrodhippi
around 90degrees
Old 12-06-2013, 07:09 AM
projectSHO89
You have a PCM-controlled clutch. The series circuit of the cycling and high pressure containment switches serve as an input to the PCM. The PCM, unless operating parameters preclude it, issues a command to energize the A/C clutch relay which, when energized, switches power from BJB F6 to the clutch coil.
The containment switch should be normally closed.
Check the fuse. See if the relay energizes, jumper the low pressure switch,etc...
Old 12-06-2013, 07:34 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
That sounds undercharged to me.
Old 12-06-2013, 09:45 AM
projectSHO89
Not at all. A low charge doesn't behave that way.
Old 12-06-2013, 09:59 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Unless the evap coil is icing, no? Those are the symptoms mine had when it was undercharged, anyhow. Of course, it would eventually pretty much stop blowing air too.
Old 12-06-2013, 02:06 PM
projectSHO89
An iced evaporator will not cause a "no power to the clutch" symptom. Iced evaporators are usually cause by a stuck cycling switch and usually manifest as "reduction in airflow that gets humid".
Low refrigerant charge usually commonly shows up as a short-cycling compressor and insufficient cooling up to the point where there isn't enough static pressure to engage the cycling switch, then it goes completely inoperative. I'm taking the OP at his word that the refrigerant is okay although he might want to expand on that since if it doesn't have enough refrigerant, it also won't have power to the coil.
Old 12-06-2013, 02:25 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Where did I say an iced evaporator would cause no power to the clutch?
Old 12-06-2013, 02:28 PM
projectSHO89
You didn't. The OP said he had no power to the clutch with effectively rules out an iced evaporator which is what I was pointing out.
Now, if the OP comes back an re-states the symptoms, then that opens up a number of options which were ruled out due to his initial descriptions.
Old 12-06-2013, 02:46 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
OK, here's my train of thought on it:
Originally, the OP said the A/C worked, but gradually faded over 30 minutes. To me, that sounds like icing caused by an undercharge condition.
Then the OP said after a couple weeks had elapsed the compressor won't run at all.
If there's a leak, that seems like the logical progression of things; now there's not enough pressure to close the low cutoff switch.
Granted, that's purely conjecture since the OP didn't say what the static pressure in the system is, nor what the pressures were when the system was operating. He did say there's power to the pressure switch, but didn't say whether he'd verified it was making it through it.
So yeah, I agree some more information would be helpful.
Pmbarrett
06-29-2011 08:54 AM
bozzzz94
Aerostar
06-30-2009 12:26 PM
maddog440
07-19-2007 09:58 AM
Pocketchange5
1997 - 2003 F150
09-23-2005 07:54 AM
Brimhall
05-28-2003 11:18 PM
Quick Reply: a/c not working
