Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Fog Light Reviews
Reviews and comparisons of top products
looking for factory fog lights for a XL
I have a 2012 XL, I just bought it a couple weeks ago. I would like to add factory fog lights. I have found factory kits on ebay form ford dealers. the problem is all the kits I am finding are for XLT and say will not work on XL. what is the difference? with the factory fog lights will they stay on with the high beams ? my 2001 XLT the fog lights would go off with the high beams. the reason I am wanting the fog lights , I am finding the factory headlights to not be very bright. looking for some extra light. I do a fair amount of back road driving and like the extra light. I have thought about adding some driving lights and using the upfitter switch , but want to keep the factory look. Any Ideas?
I did the upgrade on my 2011 XL. It required a new body control module, new headlight switch, and dealer programming of the module and key to get it to work in addition to the fog lights. If i did it again, I'd just get the factory fogs and wire to an up fitter switch. The lights go out on high beam.
I found instructions on either this forum or the diesel stop, can't remember which.
As far as I know, the factory wiring should be present to where the fog light harness would plug into, even on vehicles not equipped. I would be hard pressed to believe the BCM needing replaced though. It COULD just be a simple matter of programming As-Built data on the BCM from another identical vehicle equipped with fog lights from the factory into your existing BCM. As far as your high beams are concerned though, the fog lights will shut off on every vehicle as soon as they are turned on. Federal law requires this.
Not that I don't respect Federal Law you understand
Off Road conditions only of course
Forgive the thread jack...
The harness was there. The instructions that I got either online or from the ebay seller of the lights said I needed an XLT BCM and the headlight switch that pulls out to energize the fogs. I do remember a physical difference on the BCM - extra relay perhaps???
Not saying the "as built data" approach won't work - just the instruction I was given.
Much simpliar to just install. make harness put relay right by battery. run one wire from relay inside to a LED toggle switch, a ground, and pickup a key on power wire at fuse box. end up with a total seperate system. and can flip on or off anytime you want them. i chose not to use upfitters. as going down road its much easier to flip switch just under headlamp switch. No screwing with a BCM.or anything $5 relay $4 LED 30amp switch.
digging thru my folder I found the instructions for adding the FORD kit to the XL including the BCM install.
instruction # SKBC3J-19B532-AA can't find a soft copy on the web.
kit is $269 + shipping on ebay with the BCM.
Like I said, if i did it again, I'd go to an upfitter. Thought this might be helpful for anyone that wants the factory install.
2011 2014 Ford F 250 F 350 F 450 F 550 Super Duty XL Fog Lamp Light Kit New | eBay
Josh, I did the factory fogs on my 2012 XL. Got the kit from partsguyed.com Horizon ford.
The trick is install everything except BCM, then take BCM to dealer and have them install and program. If you change it, it wont start and you will be towing to the dealer. Otherwise, was quite straightforward.
Good luck
Good luck
Just to throw one more option at ya! I installed Baja Designs Squadron XL lights on my truck. They fit perfectly into the stock opening with a few adjustments. They also out perform every other light I have tested. They are a little more expensive though. $300-350 per light. I wired then into where the existing fogs were, so I can till use the same switch to contort it.
