Swap question - Ford Truck Enthusiasts Forums
Swap question
Old 12-04-2013, 09:52 PM
Jnowaczyk Jnowaczyk is offline
Jnowaczyk is starting off with a positive reputation.
Swap question
I have a f250 sd v10 4x4. Crew cab I found a donor truck for the enging been in a crash
It's a 99 f250 v10 sd single cab 2 wheel drive can I just drop in or ? My engine code is vin s. So as long as that one is a vin s 8 the digit should this work for a direct swap ?
Old 12-06-2013, 12:35 AM
moosey78's Avatar
moosey78 moosey78 is offline
moosey78 is starting off with a positive reputation.
Should be a direct swap. Can't see anything being different maybe the oil pan because of the 4x4. And I think the oil cooler is relocated on the 4x4 but don't hold me to that lol
Old 12-06-2013, 01:58 AM
Quote:
Ok thanks moosey
Old 12-06-2013, 08:31 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Chances are its not a direct drop in swap----issues with the ECM and the chassis wiring harness along with the engine sensor wiring harness might occur. This is primarily due the wiring harnesses themselves aren't universal and can greatly affect or interfere with proper running of the "new" motor.
Old 12-06-2013, 08:35 AM
ashleyroachclip ashleyroachclip is offline
ashleyroachclip is starting off with a positive reputation.
If all you are doing is swapping out engines , there should be no problem .
Old 12-06-2013, 12:36 PM
moosey78's Avatar
Quote:
He says the trucks are the same year. The sensors should be the same. We did a V10 swap on our 99 f250 and it was a direct swap
Need information 2007 vin 5 to 2008 vin V Tigauto 2004 - 2008 F150 3 09-17-2016 11:05 PM
U-joint size ligito 1999 to 2016 Super Duty 5 04-27-2015 12:39 PM
cab swap/VIN question Jon Hess 1973 - 1979 F-100 & Larger F-Series Trucks 24 03-13-2010 10:04 PM
1987-1991 Roof repair or cab swap crabhab Paint & Bodywork 4 12-13-2005 05:18 AM
replacing fuel tank on 2000 F250SD short bed/Crew Cab bddo 1999 to 2016 Super Duty 17 10-09-2002 11:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
