brake-shift interlock actuator
I have a 2002 ranger 4x4 4.0. Shifter hard to get out of park after applying brake, problem appears to be the mechanical actuator is sticking, lubed with spray and it helps alot but problem is stiil there. Can one remove and replace the solenoid actuator without disassembly of steering column ?
Greg Carter
04-30-2002 09:01 PM
