oil filler neck
oil filler neck
Random question here. I removed my oil fill cap today to wipe any moisture build up out from under it. I don't know if anyone else has ever experienced this but my cap twists out and in very hard, so hard it makes me worry that I might one day break the filler neck removing it. Anyway, I know that would be terrible if that happened. I thought it might be good to have a back up (if its not too much) in case that ever happened. I did some searching and can only find the filler cap. Does anyone know where to get the actual filler neck? Like I said, don't have to have it right now but I do worry if I ever do have to have it.
It is probably an easy fix, you can probably see where the threads bind, and file the tight spots down until it is a normal fit.
