3v 5.4 intake flow limitations
Old 12-08-2013, 04:00 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
I'm curious how much a stock intake can flow. I have been stockpiling info for a rebuild I want to do in the next year or so. O would like to do a slight compression bump with a .030-.040 over bore to bump power some. I would also like to port the heads and do some valve work but if the intake can't flow the air needed it won't be worth my time. Thanks for any info
Old 12-19-2013, 10:08 PM
wbrook_ford's Avatar
wbrook_ford
wbrook_ford is offline
Unless you plan on putting bigger cams in at the same time, the build will show little improvement.
The manifold should be good to 400 hp. If that's not enough then a 4.6 3V aftermarket manifold with spacers could provide even more flow.
Old 12-19-2013, 11:16 PM
nojoke327's Avatar
nojoke327
Still on the fence about cams. I do tow and don't want my power band moving to far north.
Bbolinger
1999 to 2016 Super Duty
11-06-2018 01:06 PM
Danielsm17
2004 - 2008 F150
05-14-2018 11:00 AM
ncon
Modular V8 (4.6L, 5.4L)
06-06-2010 07:34 PM
I6lover
1997 - 2003 F150
08-04-2008 08:11 AM
Quick Reply: 3v 5.4 intake flow limitations
